Online Now [1194]:
Visitors: 1193
Today: 251918
Total: 146396637
Forums › The Car › 206 Problems › help and advice
help and advice
gaznandrea
PostPosted: Tue Dec 30, 2014 2:25 am Up
These were recomended for use on here
black peugeot 206 gti 180 lowered all round morrette headlights smoked tail lights full cobra exhaust
PostPosted: Tue Dec 30, 2014 2:30 am Up
Well Bosch the company who actually make the plug don't recommend them.
gaznandrea
PostPosted: Tue Dec 30, 2014 4:41 am Up
Would these of caused the damage they have been used in my car for about 4 years this was the third set of them
PostPosted: Wed Dec 31, 2014 11:29 am Up
I can't find a Bosch FR78NX. Are you sure that really is the marking on your plug?
If you get the correct detail I can give you the difference between the plug you have fitted and the FQR7ME and possibility / probability of that being the cause.
F = 16mm AF plug spanner 14mm x 1.25mm pitch thread
Q = Quick heat.
R = Interference suppression.
7 = Heat range.
M = 26.5mm thread length with 3mm central electrode projection.
E = Nickel Yttrium electrode.
This plug has 0.9mm pre-set plug gap.
PostPosted: Wed Dec 31, 2014 11:32 am Up
That number is for a Bosch Super 4 plug & it does exist
Bosch 10 digit ID number = 0242232815
gaznandrea
PostPosted: Wed Dec 31, 2014 12:35 pm Up
Cost 350 in parts alone already
PostPosted: Wed Dec 31, 2014 8:57 pm Up
Mmmm the information on the Bosch web sites doesn't seem to cope with the "78" description. I can only assume this is either an extended heat range covering both 7 and 8 or is used to show it is midway between a 7 and 8.
So I can't give specific on heat range but either assumption will give a very small change in operating temperature and unlikely to give the effect you have suffered. Also, with so many people here recommending the FR78NX, it is unlikely to be the cause. The rest of the detail for your plug is:-
78 = Heat range?
N = 26.5mm thread length with 4mm central electrode projection.
X = 1.1mm pre-set plug gap.
You will note that the electrode projects 1mm further than the FQR7ME. This extra projection is usually done for two reasons and they are that the electrode is in a slightly hotter area of the cylinder and the hotter burn there helps stop plug fouling but it gets more of the intake air over it so that helps cool it.
As above with lots of people recommending these I would be surprised if it was the cause. If it was me though I would fit the recommended Iridium replacement for the FQR7ME rather than the super 4.
None of this really helps you find root cause.
Possible causes of burnt valves:-
Spark plug incorrect heat range.
Defective CAT.
Low octane fuel causing pre-ignition.
Running rich and carbon build up on valve seat.
Running lean causing excess combustion temperature.
Blocked water cooling system or passage ways.
General engine over heating.
Incorrect valve clearance preventing the valve fully closing when hot.
LPG conversion.
Poorly carried out cylinder head repair work after broken cam belt.
Exhaust or exhaust manifold damage or leak.
Rich or lean running ought to have thrown a fault code before it caused a burnt valve.
Project2062014
PostPosted: Wed Dec 31, 2014 9:29 pm Up
Hell yea .. someone on my level ! Man uses his own brain ..
I fitted the super 4's .
lol just go halfords read a book . All in there .. bosch i took out from the 180 & gti from standard .original factory parts . I am sure .
replaced with the super 4's.
Bosch is listed and has a part no for the gti the gti 180 . Both the same & cut bs
Edwards retarded listens to b******s( hes a newbey ) . ( joke) lmfao .
TEST BEFORE YOU COMMENT .. I DID ! 18MNTHS .
If the was wrong they would not last or even work . Test the gap ? Bs . Get a grip .
PostPosted: Thu Jan 01, 2015 3:19 am Up
I'd rather take the advice directly from Bosch automotive technical services & NOT the book in Halfords or sources elsewhere.
FQR7ME is the ONLY plug Bosch list suitable that they produce for fitment to the GTI 180 engine.
PostPosted: Thu Jan 01, 2015 5:41 am Up
Actually, as per my post, if I was looking for a performance replacement I would fit the Bosch recommended Iridium alternative. Much better than a Super 4.
PostPosted: Thu Jan 01, 2015 5:45 am Up
Also note that FR78NX has a wider gap (more than 20% wider) so will stress your coil pack. Another reason to use the Iridium rather than Super 4.
gaznandrea
PostPosted: Thu Jan 01, 2015 11:28 am Up
What is iridium replacement number
Project2062014
PostPosted: Fri Jan 02, 2015 10:05 am Up
Part no .FR7ME .. BOSCH SUPER FOR A 180 !
Im reading the code from the actual plugs . R6 392 around it & its green & white aswell !
mattymj
PostPosted: Fri Jan 02, 2015 3:10 pm Up
Last time i think i fitted bosch FR78NX
PostPosted: Fri Jan 02, 2015 3:20 pm Up
My last comment on this thread:
Page 2 of 3
