Online Now [234]:
Visitors: 233
Today: 95704
Total: 142807948
Forums › The Car › 206 Problems › How replace Passenger side front door 206 KFW 1.4 8v TU3A?
very_452001
PostPosted: Mon Jan 05, 2015 3:35 pm Up
Its a 06 Reg 206, like to know how to replace passenger side front door?
Many thanks,
very_452001
PostPosted: Mon Jan 05, 2015 3:42 pm Up
Does the means you replaced the front wing? Smile
PostPosted: Mon Jan 05, 2015 3:43 pm Up
Basic procedure I've used in the past on a 206 is.
Open the window first & get an assistant to support the door during removal & refitting.
Unplug the wiring connector at the A pillar hidden behind the black rubber tube, it has a little plastic clip that secures it in to the A pillar.
Unbolt the check strap.
Unbolt BOTTOM hinge first, then top hinge - assistant then walks away with door ( its easier to undo the long torx bolts that screws in to the car & leave the hinges themself attached to the door )
Thread lock the bolts on refitting.
very_452001
PostPosted: Tue Jan 06, 2015 11:23 am Up
Is there a picture guide on this?
very_452001
very_452001
PostPosted: Fri Jan 09, 2015 7:29 am Up
I need the following part to the door as well:
What it called? Will a replacement door come with this part anyway?
very_452001
PostPosted: Fri Jan 09, 2015 7:51 am Up
Well that part is called DOOR STOP,it's part number is (9181 C8),well I believe that this part will be fitted when you buy a replacement door,as it's easier to take the door off while keep it on,as taking this part off needs the door card to be off,and unscrew it from the inside.
very_452001
PostPosted: Sat Jan 10, 2015 7:43 am Up
Many thanks,
I checked the driver side door pillar to find out the paint code but it seems the code is faded and I cant make out what the paint colour code says.
Is there any other ways to find out the paint colour for for my car?
very_452001
Lecktorious
PostPosted: Sat Jan 10, 2015 9:27 am Up
Trade Rating: +59
very_452001 wrote:
Many thanks,
Put your VIN into Service Box and check the car specifications.
'98 Nile Blue 306 GTi 6
very_452001
PostPosted: Sat Jan 10, 2015 1:23 pm Up
Lecktorious wrote:
very_452001 wrote:
Many thanks,
What service box?
very_452001
very_452001
PostPosted: Tue Jan 13, 2015 2:44 pm Up
Is there any other way to find out without using the servicebox?
very_452001
PostPosted: Tue Jan 13, 2015 2:55 pm Up
Ask your Peugeot main dealer.
PM me the VIN number of your 206 & ill look the paint code up if you like.
very_452001
PostPosted: Tue Jan 13, 2015 6:24 pm Up
Hi I just PM the number.
very_452001
