Posted: Mon Jan 05, 2015 3:35 pm |
Its a 06 Reg 206, like to know how to replace passenger side front door?
Many thanks,
Posted: Mon Jan 05, 2015 3:42 pm |
Does the means you replaced the front wing?
Posted: Mon Jan 05, 2015 3:43 pm |
Basic procedure I've used in the past on a 206 is.
Open the window first & get an assistant to support the door during removal & refitting.
Unplug the wiring connector at the A pillar hidden behind the black rubber tube, it has a little plastic clip that secures it in to the A pillar.
Unbolt the check strap.
Unbolt BOTTOM hinge first, then top hinge - assistant then walks away with door ( its easier to undo the long torx bolts that screws in to the car & leave the hinges themself attached to the door )
Thread lock the bolts on refitting.
Posted: Tue Jan 06, 2015 11:23 am |
Is there a picture guide on this?
Posted: Fri Jan 09, 2015 7:29 am |
I need the following part to the door as well:
What it called? Will a replacement door come with this part anyway?
Posted: Fri Jan 09, 2015 7:51 am |
Well that part is called DOOR STOP,it's part number is (9181 C8),well I believe that this part will be fitted when you buy a replacement door,as it's easier to take the door off while keep it on,as taking this part off needs the door card to be off,and unscrew it from the inside.
Posted: Sat Jan 10, 2015 7:43 am |
Many thanks,
I checked the driver side door pillar to find out the paint code but it seems the code is faded and I cant make out what the paint colour code says.
Is there any other ways to find out the paint colour for for my car?
Posted: Sat Jan 10, 2015 9:27 am |
Trade Rating: +59
| very_452001 wrote: |
Many thanks,
Is there any other ways to find out the paint colour for for my car? |
Put your VIN into Service Box and check the car specifications.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Sat Jan 10, 2015 1:23 pm |
| Lecktorious wrote: |
Many thanks,
Put your VIN into Service Box and check the car specifications. |
What service box?
Posted: Tue Jan 13, 2015 2:44 pm |
Is there any other way to find out without using the servicebox?
Posted: Tue Jan 13, 2015 2:55 pm |
| Is there any other way to find out without using the servicebox? |
Ask your Peugeot main dealer.
PM me the VIN number of your 206 & ill look the paint code up if you like.
Posted: Tue Jan 13, 2015 6:24 pm |
| MrBSI wrote: |
PM me the VIN number of your 206 & ill look the paint code up if you like. |
Hi I just PM the number.
