Posted: Thu Jan 08, 2015 12:56 pm |
Hey all, I have spent ages trying to find out a solution for this and posted some questions on here in other topics that might not be the right place.
When I push the key fob button (two button type) sometimes my central locking kicks in and other times it doesn't. I have tried different locations, distances etc but it seems really random. Sometimes I can spend AGES trying to unlock or lock the doors and have to use the key in the door.
I have found some places on line that will repair the key but am not sure if it could be the sensor in the car, does anyone know how i would test and has anyone used these repair places and had any issues?
Posted: Fri Jan 09, 2015 5:46 am |
Well this can be caused by 2 reasons,maybe a faulty remote control (transmitter),or the receiver antenna fixed around the ignition barrel.
Posted: Fri Jan 09, 2015 7:43 am |
Cheers for the reply, any idea on how to test which one it is? I don't want to send the key away to be fixed if it doesn't have an issue
Posted: Fri Jan 09, 2015 8:36 am |
if the antenna is faulty,that will appear in diagnostic using pp2000,but about the key,it can be checked in a locksmith store,as they have gadgets that check the signal when you press on the key buttons.
Posted: Fri Jan 09, 2015 1:36 pm |
Legend Timon! i will get the key tested at our local locksmith tomorrow, thanks for the idea Will keep you posted.
Posted: Fri Jan 09, 2015 2:26 pm |
Spotfist wrote: |
Legend Timon! i will get the key tested at our local locksmith tomorrow, thanks for the idea Will keep you posted. |
Thank you,I hope that I help you as much as I can,good luck.
Cheers,
Tim
Posted: Sun Jan 11, 2015 10:50 am |
Any Updates?
Posted: Sun Jan 11, 2015 2:18 pm |
Ye the locksmith said "Oh the main dealers took all that kind of work from us" and suggested I go to peugeot, but i was going to see if i can try a few other locksmiths first. There is one that specialises in cars.
Posted: Sun Jan 11, 2015 2:22 pm |
Mmm...that is not good news..hope the one left can do so..good luck.
