Latest: eltel666
Overall: 17146
Online Now [200]:
Visitors: 198
Members: 1
Today: 24395
Total: 116161384
Forums › The Car › 206 Problems › 206gti water leak
206gti water leak
DrunknMonkey
PostPosted: Sun Jan 11, 2015 11:46 am Up
I have a 206gti that has produced a water leak coming from the timing belt side. So I have replaced the water pump but it is still leaking in the same place can any 1 help please
PostPosted: Sun Jan 11, 2015 12:20 pm Up
have you replaced the water pump gasket when you replaced the water pump?
PostPosted: Sun Jan 11, 2015 12:22 pm Up
Also check the water pump pipe,that goes out from the water pump housing,maybe it need to be replaced
DrunknMonkey
PostPosted: Sun Jan 11, 2015 12:34 pm Up
Yes I have replaced the 2 rubber sills that come with the new water pump there was no gasket. The water seems to be coming from the timing belt area
PostPosted: Sun Jan 11, 2015 1:25 pm Up
take the timing belt cover and check it with a light,to see where the leak is,you can pressure test it while engine is cold,and see where the weak point is.
DrunknMonkey
PostPosted: Sun Jan 11, 2015 1:35 pm Up
Ok thanks that was my plan to do through the week
