Online Now [120]:
Visitors: 120
Today: 29643
Total: 143338614
Forums › The Car › 206 Talk › 206 GTi 138 - Clutch Recomendations
Go to page Previous  1, 2
PostPosted: Tue Jan 13, 2015 6:34 pm Up
Are they larger diameters? If not i wouldnt worry, i may consider a paddle clutch as you did say about future engine upgrading
PostPosted: Tue Jan 13, 2015 6:47 pm Up
Not so sure about diameter, I think the 180 one is a tad lighter than the 138. I'll have to pull the one out of my scrap 138 lump and weigh them both.
PostPosted: Wed Jan 14, 2015 6:25 am Up
Well the thrust bearing decided to well and truly s**t itself this morning, and take out the crank sensor with it. Picking up an LUK clutch this afternoon for £86.26 + VAT. Car will be back on the road by this evening.
PostPosted: Wed Jan 14, 2015 6:33 am Up
No comment Whistle...
PostPosted: Wed Jan 14, 2015 6:42 am Up
Serves me right for trying to be organized about it all. Could guarantee if I hadn't have given it so much as a second thought it would have lasted until next week when I was planning on getting it up on axle stands for a couple of days.
Ah well, ive got a couple of good crank sensors lying about. Few hours in the garage this afternoon and it'll be good to go again.
David1156
PostPosted: Wed Jan 14, 2015 10:15 am Up
Had the same problem myself. The clutch was fine but the cable and thrust bearing failed. I don't reckon it's possible to get an uprated thrust bearing in general?
Current: Albi Blue Clio 197
PostPosted: Wed Jan 14, 2015 10:21 am Up
Right hand drive GTI is a hydraulic clutch so there isn't a cable to worry about - just a slave cylinder instead.
The standard thrust bearing with a decent brand of clutch kit will be fine.
PostPosted: Wed Jan 14, 2015 5:01 pm Up
Bit of grease on the input draft for the bearing doesn't hurt either. I replaced my salve cylinder as well when I did mine. Old one had a leak in it somewhere. Had to bleed it every few months.
PostPosted: Thu Jan 15, 2015 4:03 am Up
Well this is what came out of the bell housing, all that was left from my thrust bearing and crank sensor....
WP_20150114_20_55_19_Raw by LeeThr, on Flickr
Took me about 5 hours from getting the car off the floor to it coming back down. Just need to find my spare radiator now and change that, box came out a slightly awkward angle and just managed to catch the very corner of the radiator. But other than that everything else went smoothly. Not a bolt short or a bolt left over either Smile
Page 2 of 2
