Latest: tebas93089
Overall: 17179
Online Now [202]:
Visitors: 202
Today: 27020
Total: 138546635
Forums › The Car › 206 Problems › Clutch pedal dropping to floor randomly?
Ruuhkis
PostPosted: Thu Jan 15, 2015 8:52 am Up
Hello!
It all started in december when I was leaving my girlfriends place as usually but when I hit the clutch pedal it dropped all the way to floor with no effect to the actual clutch
After that it was loose and I thought the clutch cable broke, but no, after raising the pedal by hand back to its default position it started to work again, I was confused!
After that, the next day, it happened again, once, then there were no clutch problems til last week, all the sudden, the clutch pedal went loose again, but as I raised pedal back to default position it started functionig..
It happened again just now and I am just tired of it, and would like to know what could it be and what can be done?
My peugeot is from early 2006 if that makes difference
Kind regards,
Pasi
David1156
PostPosted: Thu Jan 15, 2015 8:58 am Up
I had the same problem as you. The auto adjuster is failing. This is part of the clutch cable and you'll need to fit a new clutch cable to fix it.
Current: Albi Blue Clio 197
PostPosted: Thu Jan 15, 2015 8:59 am Up
Which engine is it & is it left hand OR right hand drive.
The clutch is either cable operated OR hydraulic, which set up you have depends which engine you have & which side the steering wheel is on.
Ruuhkis
PostPosted: Thu Jan 15, 2015 9:08 am Up
1.4 HDI engine and its driven from left side, which one is it then?
PostPosted: Thu Jan 15, 2015 9:10 am Up
It will be a CABLE clutch on yours as it's left hand drive.
Ruuhkis
PostPosted: Thu Jan 15, 2015 9:23 am Up
So the auto adjuster is failing and I'll need the cable changed?
Hopefully it doesnt break alltogether before I get it changed
PostPosted: Thu Jan 15, 2015 9:26 am Up
If your lucky it will be the auto adjusting cable BUT the clutch on the MA gearbox is known for the release bearing to eat its way through the pressure plate springs given very much the same symptoms.
Cross your fingers & replace the cable BUT also don't be surprised if it wants the clutch kit replacing.
