Latest: lio94
Overall: 17181
Online Now [103]:
Visitors: 102
Today: 112308
Total: 140336220
Project sleeper
Go to page Previous  1, 2, 3 ... 22, 23, 24 ... 85, 86, 87  Next
macj
PostPosted: Fri Mar 26, 2010 2:10 pm Up
You will be fitting a roll cage and joining me on a rally stage soon Very Happy Very Happy
tRiCk
PostPosted: Fri Mar 26, 2010 2:31 pm Up
Edward wrote:
Took the car home through the scenic route today...it does go quite nicely and it does make a nice sound, you can't go fast discretely though...
It is a bit unruly for everyday use but it is fun once it has some revs on the engine. It's quite good fun and I actually like it again. I do think for sustained hard use an oil cooler would be a wise move. It does run hotter than it did before.
I'm still buying another car though!
I totally agree with you ed its hard to give it some without looking/sounding to suspicious haha.
what are you thinking of as a daily driver then??
Same here. Slightly annoying. Power that im not allowed to use.
spike_202
PostPosted: Fri Mar 26, 2010 3:00 pm Up
lol at trick oh i make good use of it haha i just have to choose my times carefully as its like a rally car.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Mar 26, 2010 4:07 pm Up
That would mean getting it dirty.
macj
PostPosted: Sat Mar 27, 2010 5:14 am Up
Shocked Shocked Shocked Shocked Shocked
Antix
PostPosted: Sat Mar 27, 2010 6:01 am Up
Custom - Red Stars
'All show and all go' now, Edward Wink
Dave
PostPosted: Sat Mar 27, 2010 6:19 am Up
'Detailed, not driven' ? Laughing
White Mk 5 Golf Gti
PostPosted: Sat Mar 27, 2010 9:19 am Up
I did some fiddling today. I wanted to know what was in the airbox as I noticed Ecosse hadn't used 5 of the bolts to hold the bottom of the lid onto the airbox (making it easier for me to take the lid off!).
It's the five bolts on the lower row of the box that haven't been used.
This is what's inside the box.
The bottom of the airbox behind the radiator isn't held together and therefore isn't perfectly sealed. I fully understand why they haven't bolted it together simply because there is just no space for tools etc. There is about 5mm between the airbox and radiator so it's impossible to get access. Either the radiator and fan housing would have to be removed to fit the bolts or the whole inlet and bodies removed to do the airbox bolts up.
So I though of an alternative. Some simple cable ties to hold the lid onto the box are better than nothing. They are a bit fiddley to fit but they don't need tools to do them up. They also just need some cable cutters to remove them.
There is also a bit of oil in the airbox from the breather pipe. It's not excessive but I might look into buying an oil catch tank. Anybody know how they work? Do they still use air going into the inlet to pull the vapours out of the engine?
Even though I don't think the strut brace does anything to benefit the handling of the car I thought I might as well fit it. It does finish things off nicely.
Also had a bit of 'help' from the dog.
Nick
PostPosted: Sat Mar 27, 2010 9:23 am Up
thank you Edward you just brought loads of smiles into my day
I have a car
Antix
PostPosted: Sat Mar 27, 2010 9:24 am Up
Custom - Red Stars
did the dog also make the mess in your yard? Wink Laughing
I like the red strutbrace - it goes with the other red thing in your engine bay, by the Longman carbon box
PostPosted: Sat Mar 27, 2010 9:29 am Up
I did the mess of the driveway. I decided to finally fix the bathroom drainpipes to the walls hence the need for ladders etc. I only finished the bathroom last June!
Antix
PostPosted: Sat Mar 27, 2010 9:34 am Up
Custom - Red Stars
what's next on the 'to do' list? [car-wise I mean]
Jamie
PostPosted: Sat Mar 27, 2010 9:35 am Up
It doesn't really matter which catch tank you go for, they are very basic in design, but I imagine the branded ones are made better, ie stick to Mocal/Forge/Baileys.
Have it set up so it drains back to the sump if you can, rather than having to empty it every so often!
What have Ecosse done in the way of a "breather"?
spike_202
PostPosted: Sat Mar 27, 2010 11:56 am Up
i said you would need one,espesh when your in the cam it will push more oil out i had mine custom made, and they are a good idea with a return like what jay said but if the pump packs in and it sifenz it will contaminate the engine,
And it was spot on what they did with the air box, thats what im doing with mine when i get round to it lol.
**spike's project**
TEAM:+200bhp
Seb
PostPosted: Sat Mar 27, 2010 12:18 pm Up
Staff - Seb
Watch the catch tanks sometimes, they can fill up with water for some reason!
Page 23 of 87
