Online Now [308]:
Visitors: 307
Today: 27117
Total: 142648948
Forums › The Car › 206 Problems › display fault
display fault
Townie93
PostPosted: Fri Feb 06, 2015 5:56 pm Up
www.facebook.com/photo...mp;theater why dont this work (lights are on)
PostPosted: Fri Feb 06, 2015 6:28 pm Up
Content unavailable
Try posting the picture using photobucket or similar
You could even try explaining what the fault is
Townie93
PostPosted: Fri Feb 06, 2015 6:38 pm Up
s1068.photobucket.com/...0.jpg.html sorry
mtempsch
PostPosted: Sat Feb 07, 2015 3:17 am Up
Townie93 wrote:
http://s1068.photobucket.com/user/chris_townsend4/media/DSC_0007_zpso1qz7jn0.jpg.html sorry
Is the problem no backlight? (one can usually tell if the bulbs are lit even if no data is showing), or that no data is showing? Could try removing the bulbs and shine through the holes with a flashlight to see if data is there...
Not lit at all - go for the basics, check the bulbs. The connector on the circuit board of the display is somewhat fragile, and pin(s) might have come loose. Possibly solvable with a bit of soldering.
If not one of those you'll need to check the wiring further upstream (are all other dials and buttons lit?)
If lit but no data - first try a BSI reset. Done any stereo or other electric work recently? Voltage out from the stereo applied to one of the bus wires in the car might lock up the bus, blocking communication to the display (but then it usually shows last image, just not updating properly)
If none of the above, then my guess would go to a broken display.
Silvermetallic 2004 206 RC
PostPosted: Sat Feb 07, 2015 6:19 am Up
www.206info.co.uk/Foru...ppt30.html
Its a ppt30 display, the pin inside has most likely come off (as 99% of the time) so you need to solder it back on.
No pics in above link but maybe text will help you get the jist of it. easy fix
