Online Now [157]:
Visitors: 157
Today: 64593
Total: 105327861
Forums › The Car › 206 Problems › 206 2001 GLX
206 2001 GLX
ox141jf
PostPosted: Fri Feb 06, 2015 6:53 pm Up
I has a 1999 lx 206 which had an obd 2 port but it did nothing, i have not got a 206 2001 glx and the obd 2 port works with my adapter but i only get RPM and error codes.
is that all the ECS supports?
sean.r.steward
PostPosted: Sat Feb 07, 2015 1:55 pm Up
Is it diagnosis capabilities you are talking about
Youtube
eric the car guy
or scanner daner
ox141jf
PostPosted: Sat Feb 07, 2015 3:33 pm Up
yes theobd2 only gives me rpm and error codes not speed, fuel etc
PostPosted: Sun Feb 08, 2015 12:25 am Up
Vehicles only became EOBD compliant in 2001 for petrol models, so your 1999 model probably wouldn't connect using cheap diagnostics equipment.
Are you using a hand held scanner or PC with a wire? If the latter then which software are you using? I've had a 99 diesel connect with no problems and they only needed to be compliant from 2004
sean.r.steward
PostPosted: Sun Feb 08, 2015 7:38 am Up
does pp2000 give you those parameters?
