Latest: Beduff1977
Overall: 17134
Online Now [533]:
Visitors: 532
Today: 54390
Total: 108390791
Forums › The Car › 206 Talk › 206 styling
206 styling
Go to page Previous  1, 2
raz24
PostPosted: Sat Feb 14, 2015 3:04 pm Up
Cheers I will do was yours modified at all when you put the 205/40/17s on.
raz24
PostPosted: Sun Feb 15, 2015 5:51 am Up
Right guys think I've just found my h7 clips on my 206 they are two pins opposed to h4 3 pin?
Is it just plug in and play or do I need to do something else to the car?
mtempsch
PostPosted: Sun Feb 15, 2015 9:31 am Up
No, should be the 3 as well (high, dipped and ground, but in a smaller grey rectangular plug. Internally to the light cluster there will be two separate 2-pin plugs, one for each H7 bulb, rather than the 3-pin h4-plug.
See this pic. The main connector is the grey one in the foregound just above the adjuster.
Edit: You'll either have to tell your BSI that you now have dual optics (so it keeps the dipped beam on when the high beam comes on instead of as with H4 turning the dipped off, OR create another alternate powerfeed to the dipped beam bulb, using a double thow relay controlled by the high beam wire, so that with high beam off the relay routes normal harness to the bulb, when the high beam comes on (and the normal harness turns off the the dipped line)), the relay instead connects a line from the battery to the bulb, keeping power going to the dipped bulb that way while the high beam is on. Search, it's been covered before here.
Silvermetallic 2004 206 RC
raz24
PostPosted: Sun Feb 15, 2015 12:05 pm Up
Is there any chance you could upload a picture off all the connections needed for the crystal conversion to work. I can't upload to the page but think may be missing a few.
mtempsch
PostPosted: Sun Feb 15, 2015 1:05 pm Up
How do you mean? The connections / mods regarding the relay?
raz24
PostPosted: Sun Feb 15, 2015 3:18 pm Up
Sorry for delay.
I mean all the OEM connections that should be in the car I could do with seeing which connection are needed.
Then if I cant find them in my car I would also like to see any mods regarding fitting the lights with a h4 connection?
If this makes any sense please help me.
raz24
PostPosted: Thu Feb 26, 2015 4:55 pm Up
Wheels have come back from refurb and had tires fitted, my personal opinion is that they set my car off and make it look 100 times better next steps I think I want to do is the crystal headlights. What will this involve I beleive I have found the relevant cables needed to plug the lights in. I want to de-badge the front and put a phase 2 boot strip on the back to have the smooth effect but some jealous fu**ers have scratched my boot and roof. Also anyone selling any wind deflectors for a 3dr.
Tyres are for sale too 205/50/17 x2 Nanking ns-2
Oafie
PostPosted: Thu Feb 26, 2015 5:54 pm Up
Hi mate, I've got some crystal headlights and the phase 2 bootstrip for sale if your interested.
the bootstrip is in black and I want £10 + postage for it, £30 +postage for the headlights
Ian.
raz24
PostPosted: Fri Mar 06, 2015 4:21 pm Up
Anyone of you guys who have a peugoet planet software based around Lancashire I want to install crystal lights but I want the beams to work at the same time.
Still looking for crystals and moonstone parts. Not wanting to spend a fortune the seats,wheels and tyres cleaned me out well and good
Page 2 of 2
