I just bought used 206 from 2001. I got some problems with it:
1. My MFD is blank, it lights up but the screen is black. Should i just buy other MFD or can i try something else? If it matters also the car does not have radio.
2. After changing some light bulbs in the cluster and putting back the cluster in its place when i turn ignition fuel reserve and airbag light are always on no matter what i do. I tried and with ignition on i took of the reserve bulb the airbag light went of. I reinstaled the bulb and now airbag lights and then goes off like it should, but reserve light is always on. Solution?
