Latest: Kifi69
Overall: 17183
Online Now [371]:
Visitors: 370
Today: 71376
Total: 143489055
Forums › The Car › 206 Talk › 206 diagnostics..
206 diagnostics..
old-muggins
PostPosted: Wed Mar 04, 2015 10:58 pm Up
Hi all,
Im thinking of buying one of these for my use on the 1.4hdi i Have for any future problems.
Afaik his name is jim and has been recommended via peugeot forum. www.easydiagnostics.co...c)/8000814
i want something that will allow me to do anything i need i.e bsi update to correct the trip mileage issue of taking last 3 digits from total mileAge. Diagnose and clear fault codes. Code fuel pumps if needed
will this allow me to do this kind of work.
Id like a diagnlstic system like the above, so not paying an arm and a leg for pp2000 as some say they have on ebay at 500 quid. When they show lexia 3 hardware and the software.
Anyone have any recommendations?
Rob
PostPosted: Thu Mar 05, 2015 2:01 am Up
You need to log on to the Peugeot internal server to be able to do a BSI software update.
Citroen Lexia & Peugeot Planet use the same interface hardware which is now combined in to Diagbox.
The cracked software is easy to find on the internet, your basically just paying for the interface & leads.
Version 7.64 is the current cracked Diagbox software.
Apart from not be able to do BSI software updates this will work fine.
Also turn your internet access OFF when using it Wink
old-muggins
PostPosted: Thu Mar 05, 2015 4:28 am Up
Ah, okay so pointless buying this lot then, may aswell just buy the interface and download what i need then. How nuch roughly would it cost for pug to update bsi?
Thanks for the info fella! Smile
gazza82
PostPosted: Thu Mar 05, 2015 9:37 am Up
I got my interface cables from aliexpress (from far east) and downloaded PP2000 from peugeotforums site. Job done for about £65!
I didn't use the software disc in with lexia data as I ran an Anti-virus scan on it ... it went in the bin once I got the downloaded software to work!
PostPosted: Thu Mar 05, 2015 10:35 am Up
The anti virus scan identifies the crack as a virus. Pretty standard on any software that contains a crack.
Best thing to do is turn off live scan while you install it and then turn it back on once done.
PostPosted: Thu Mar 05, 2015 2:58 pm Up
I get software updates for free if that helps? Laughing
PostPosted: Thu Mar 05, 2015 3:04 pm Up
Im running Diagbox version 7.57 at the moment but I do have the 7.64 update stashed safely away but as Diagbox is working fine & its only scanning a 206 I don't want to fiddle with updating it.
Apparently someone somewhere has used a Peugeot server log on with a clone interface, it was quickly picked up & blacklisted Laughing
PostPosted: Thu Mar 05, 2015 3:10 pm Up
f*** using my D number for downloads then Laughing
I honestly cant tell you what version we are on now, but we still use PP2000 for anything with a CAN CAN or VAN CAN system, ie pre facelift 307 or 206s
PostPosted: Thu Mar 05, 2015 3:24 pm Up
When I use Diagbox on the 206 it basically just opens up good old Peugeot Planet Cool
