Latest: SA01
Overall: 17138
Online Now [83]:
Visitors: 82
Today: 24779
Total: 112147422
Forums › The Car › 206 Problems › Anti Pollution Fault
mike_bngs
PostPosted: Wed Mar 11, 2015 3:23 pm Up
This warning has been flashing up for about three weeks, the engine light is on as result. However I am not loosing power or anything else, is this an MOT worry?
Hawkers
PostPosted: Wed Mar 11, 2015 3:50 pm Up
Anti Pollution Fault is a very generic message and is basically the cars way of saying something is wrong with your car. Until you get it to a garage with (ideally) peugeot specific diagnostics equipment then you'll never know what the fault is.
I don't think it can fail from having the engine light on, but if the fault is something to do with the emissions etc then it'll fail on that.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
PostPosted: Wed Mar 11, 2015 5:32 pm Up
I think EML light on is a fail, as well as ABS light being on.
PostPosted: Thu Mar 12, 2015 1:56 am Up
Not sure if it's only an advisory. It seems to have been one of those grey areas that VOSA keep on leaving.
The rules say that the warning lights on the dash must illuminate and then go out once the engine is running. Some people say that the examiner has to visually check that warning lights for electronic stability control, safety restraint systems, anti-lock braking systems and tyre pressure monitoring systems. No mention of the EML.
Some say that the EML is checked as on safety grounds a fault with the engine could create a hazard.
There is also the argument that if the EML is on due to an anti pollution fault, then it's likely that the car will fail on the emissions test anyway so the EML has no significance.
PostPosted: Fri Mar 13, 2015 3:21 am Up
And driving with EML light on could be destroying your catalytic converter.
tomhollo21
PostPosted: Tue Mar 17, 2015 4:19 pm Up
I had the same thing come up and I plugged into with my machine and one of the fuel injectors was playing up and today it went completely now it's only running on 3 cylinders so you should get it checked asap
Conrad1987
PostPosted: Mon Mar 23, 2015 5:50 am Up
eml light is not mot a mot fail and depending on what engine is fitted could be any number of reasons why the light is on
