Forums › The Car › 206 Problems › 206 front brake Fixing hole centre width. |
Posted: Mon Mar 16, 2015 4:19 pm |
Does anyone know the width of the fixing attatchment holes on the gti front brakes?
Any help would be very grateful
| 1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170 | |
Posted: Wed Mar 18, 2015 4:31 am |
Not really sure which measurements you need, disc centre hole, pad size or whatever but if you go to the eurocarparts site and type in your reg, your car model will be shown and from there you can look up which part you need with dimensions. Pretty good with my 02 206 and the Wife's car but as always there may be variations. They will say if that's the case. Hope it helps.
Posted: Wed Mar 18, 2015 10:28 am |
I'm after the hole centre to hole centre on the caliper mounting points. I'm sure someone will know
