Online Now [296]:
Visitors: 295
Today: 15395
Total: 142637232
Forums › The Car › 206 Talk › THE OFFICIAL 206 GT REGISTER
cat41
PostPosted: Thu Jan 01, 2015 7:13 pm Up
I may well be needing calipers, the handbrake only works if i,m breaking my arm, i need a shoulder oparations and this isn't helping. there's a brake weight addjuster as well which i have never heard of, been told all cars have this, it was rusted solid but i think its ok, what a stupid design, in English weather and salt its killed it to be honest.
The cars right wing mirror is wobbly inside but can't seam to get it apart, its retractable type.
Not being funny but any tips on more grunt, it has a pipe cross filter and i,m sure it has a none standard rear box because its so loud. I,m an x biker so cars feel pretty dam slow. But really like the gt even tho its got a mind of its own, if i let it it will wonder of in fields lol.
I,m seing my macanic monday, will look again at its rear brakes, if they no good i may well let you know, what condition is yours?
macj
PostPosted: Fri Jan 02, 2015 6:59 am Up
Lets try to deal with this one at a time. I remove the brake compensator as the MOT states it "has to work if fitted". I have taken it off my rally car for obvious reasons but you need a good mechanic who can remake the brake pipes up to keep your diagonally opposed system working. Alternatively you can free yours up with WD40 and elbow grease.
The handbrake would benefit from rear discs and pads if the cables are free. As the rear brakes do very little work on a GT they tend to rust pretty quick. Rust does not make for a good braking surface.
The mirror issue can only be solved by buying a second hand set which is two mirrors and the switch. It would break up a set otherwise.
Hope it helps
cat41
PostPosted: Wed Jan 07, 2015 5:33 pm Up
Job done today and so difficult, those lower arms and their pins wone come out, something is so odd, i simple job of 3 hours turned out to be 7 hours.
New shocks, strut mounts, track rod ends, and 1 right side antiroll linkage. Its now handling very well, nive and tight streering.
The shaking was a badly damaged wheel so thats scrap.
Does anyone has issues removing lower arms on the 206,
Next is rear axle grrr 170 quid.
Garylfc1
PostPosted: Thu Jan 08, 2015 4:00 am Up
1140 - V39 JVC - Macclesfield - No mods but only 37000 gen miles
Shadowstalke
PostPosted: Thu Jan 08, 2015 4:29 am Up
1468 - Reg Unknown - For Sale on Facebook (206 Owners Club UK Page) in Walsall area
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
cat41
PostPosted: Fri Jan 09, 2015 6:15 pm Up
my Gt, it's a work in progress.
pipe cross filter, none standard rear box, centre and vent trims done in silver. silver mesh front grill, had to make this myself, oil catch can with home made filter, still to fit.
it's had new front shocks, track rod ends, osram bulbs, atiroll links and struts.
cam belt. restored leather by me.
problems it had, despairing coolant, cooling fan not working, air bag lights on.
coolant issues was broken pipe on the expansion tank, fan was a relay.
wheels are in very bad condition and may well get new ones, i'm thinking of gun mental grey thin spokes with polished rims.
still to fix, rear axle is knacked, rear breaks not working well, air bad modual needs replacing. rev counter slightly off.
wish list replace its rear boot with one that has the gti fin.
speakers are so bad i can't use them, they need replacing with some good ones.
having sat nav power cable fitting in the roof.
mattox2014
PostPosted: Mon Feb 09, 2015 4:07 pm Up
just become owner of peugeot 206 gt grand turismo (1454)
206gt160
PostPosted: Tue Feb 10, 2015 12:24 pm Up
Welcome to the Gt world
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
bigsafej
PostPosted: Fri Mar 20, 2015 2:22 pm Up
I own GT 1593, W4** NAL, 73000miles, completely standard apart from OZ alloys, just had a full respray, work in progress, Hawick - Scotland.
nockg
PostPosted: Fri Apr 10, 2015 10:09 am Up
1196 - V180 LAF - I've owned it since November 2014. It's still standard with 105,000 miles. Needs a good service!! It's in Stourbridge, West Midlands.
Rangie999
PostPosted: Sat Apr 11, 2015 9:04 am Up
1038 - V...POA alive and well in Norfolk. Have just rebuilt the back axle, front suspension and brake lines after being off road for 4 years. Straight through the MOT and having the bodywork tidied up and wheels powder coated. Always wanted a GT for some reason since they first came out. Finally scratching the itch.....would love to know more history of my car other than a spares project from an ebay trader!!
PugGT1051
PostPosted: Thu Sep 03, 2015 11:45 am Up
1051 - T669 EGX - Basildon - Standard Car no modifications at present, but this car will be back to it's finest within the next 12 months. Planned works are wheel refurbishment, interior re-done standard (Mint condition), new spoiler, custom stainless exhaust.
Peugeot 206 Grand Tourisme 1051
Mikkenu123
PostPosted: Mon Apr 04, 2016 1:22 pm Up
# 2893 it's mine and Runs in Norway
akusas
PostPosted: Thu Jan 19, 2017 8:53 pm Up
Hi all, mine GT Nr 2951is runnig fast in Lithuania Very Happy
Samthomas1990
PostPosted: Tue Jan 02, 2018 11:39 pm Up
I’m looking to buy a 206 Grand Turisme can anyone point me in the direction of a good one please ?
Page 7 of 8
