Latest: tbafonso
Overall: 17130
Online Now [168]:
Visitors: 167
Today: 1268
Total: 103969221
Forums › The Car › 206 Talk › Lowering 180
Lowering 180
lisa206
PostPosted: Wed Apr 01, 2015 5:38 pm Up
Hi all,
Want to lower my 180, anyone know if a 50mm drop all round would be too much ???
Anyone lowered there's to 50mm??
LISA 206 180
Project2062014
PostPosted: Wed Apr 01, 2015 8:21 pm Up
Mines 50mm drop all round ..
Perfect for me . Does catch now and again on major speed bumps ..
Vexs
PostPosted: Thu Apr 02, 2015 2:15 am Up
50mm is a little excessive, 30mm usually looks good and still rides OK without scraping, don't forget your wheel arch trim fills some of the gap out so you don't need to go as low as you think.
My GTI 180
My Old 1.4 8v
PostPosted: Thu Apr 02, 2015 2:53 am Up
30 mm is the perfect drop. Looks purposeful and remains driveable too.
Project2062014
PostPosted: Thu Apr 02, 2015 3:00 pm Up
It also rubs the arch liners on full lock .
25/30 mm probably best. These boi's do speak from experience..
I just like sitting on the floor.. Wink
The sump is the target area(lowest point) so be wise.
