Posted: Fri Apr 03, 2015 2:59 pm |
Hi I have a 206 1.9 d non turbo. When I turn the car off it sounds like a relay is constantly on in the engine bay and it sounds like the clicking is coming from the fuel pump it sometimes also flicks the glow plug light on and off. Has anyone else experienced this or can help please. Even if the car is off for an hour it sometimes still clicks.
Posted: Fri Apr 03, 2015 3:57 pm |
Just to add the car starts and runs ok but worried about this draining the battery and causing other problems
Posted: Wed Apr 08, 2015 10:02 am |
Ok the relay has stopped constantly going on and off and now I've got an engine management light on with code P0215, main relay fault. And P0122 control collar travel sensor. The car still starts and drives fine but really need to sort this please can someone voice some input....will replacing the fuel pump relay be a good place to start and I'm guessing it's the one under the ECU?
Posted: Wed Apr 08, 2015 11:03 am |
