Latest: cogeim7
Overall: 17185
Online Now [1143]:
Visitors: 1142
Today: 124346
Total: 147422380
Forums › The Car › 206 Problems › May have found the cure for the leak on my 180
mattymj
PostPosted: Thu Apr 02, 2015 3:50 pm Up
This washer goes between the oil cooler, further up.
I wonder if I replace it if it needs to be torqued up?
PostPosted: Fri Apr 03, 2015 3:42 am Up
Well done Very Happy
gpvecchi
PostPosted: Fri Apr 03, 2015 2:29 pm Up
Nevermind, I tried all the things, I changed 3 gaskets, I torqued it up, down, no way. After a week the oil leak comes back.
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
ukskater01
PostPosted: Fri Apr 03, 2015 3:58 pm Up
Wash the oil off with a jet wash and then recheck after a drive to see where it's coming from
mattymj
PostPosted: Tue Apr 07, 2015 6:01 pm Up
Shall hopefully be getting my new washer Thursday. When refitting is the a torque setting for the big bolt that screws through the oil cooler?
oldskoolz
PostPosted: Wed Apr 08, 2015 7:11 am Up
I would imagine there is considering there is a gasket behind it. Try it as hand tight plus a quarter turn and see from there, most rubber seals will be crushed beyond this point.
Black 206 Gti. Soon to be 2.2
PostPosted: Wed Apr 08, 2015 1:23 pm Up
Would it hurt to put sump sealant on the outer edges?
mattymj
PostPosted: Thu Apr 09, 2015 8:38 am Up
I have the new seal. Peugeot state a 8 nm tightening! Isn't that hand tight?
oldskoolz
PostPosted: Thu Apr 09, 2015 8:48 am Up
Without a torque wrench its hard to say
mattymj
PostPosted: Thu Apr 09, 2015 8:57 am Up
Could go for hand tight plus a 1/4 turn!
mattymj
PostPosted: Thu Apr 09, 2015 10:38 am Up
Not too much difference
mattymj
PostPosted: Thu Apr 09, 2015 12:13 pm Up
I found the cooler had lines on it so I hand tightened it then aligned it square
Project2062014
PostPosted: Fri Apr 10, 2015 9:02 am Up
Shoot me
PostPosted: Fri Apr 10, 2015 9:25 am Up
Leegsi
PostPosted: Fri Apr 10, 2015 2:15 pm Up
So did it sort your leak?
