Online Now [538]:
Visitors: 537
Today: 163211
Total: 145468869
Forums › The Car › 206 Problems › 206 Gear problems
206 Gear problems
Mozzie
PostPosted: Mon Apr 13, 2015 3:48 am Up
Hi there
I have been trying to fix the Wife's t plate 206 for a week now, It started when she had a grinding noise coming from the front end when she released the clutch, i was told the drive shaft cv joint had gone behind the wheel, I changed them but it still wont go forwards or backwards, Even when i have the car in reverse it will roll forward.
When you think you have engaged a gear the car wont move when you release the clutch, but the speedo will move at one point the car was doing 70MPH while standing still. I haven't checked the gear linkages yet going to do that today. Does anyone have any ideas as to what it could be, i am desperate to get this car going as the Wife is using mine Sad . Many thanks for reading
PostPosted: Mon Apr 13, 2015 4:02 am Up
Sounding like diff failure.
To get a reading on the speedo & no actual movement is the clue.
Mozzie
PostPosted: Mon Apr 13, 2015 4:11 am Up
Thanks for the reply. Does that mean a gearbox change or is it a simple ish fix
Mozzie
PostPosted: Mon Apr 13, 2015 5:04 am Up
Just done the test where you spin1 wheel and the other one should rotate and nothing happened.so it is the diff what gone. Is it a big didifficult job
PostPosted: Mon Apr 13, 2015 6:53 am Up
What engine, should be cheap enough to replace the gearbox. Might be a bit more if you need to pay someone to do it. Might as well do a clutch change whilst your in there as well.
Mozzie
PostPosted: Mon Apr 13, 2015 7:01 am Up
Hi mate its a 1.1 been quoted £65 from scrapyard for gearbox , just need to find someone local who would fit it for me for a price of course
PostPosted: Mon Apr 13, 2015 7:23 am Up
Change the clutch release bearing and guide. For a smooth quiet gear change
Mozzie
PostPosted: Mon Apr 13, 2015 9:55 am Up
Cheers guys for the help, i am away tomorrow until next Monday so i am going to try and find someone local to me to come and fix it , at the moment it stuck on father in laws drive, i will have the gearbox ready and waiting just need some one to swap it over.
Mozzie
PostPosted: Wed Apr 22, 2015 12:08 pm Up
Right, i took the gearbox off and there was hole in the casing inside, got another working box from scrapyard am going to fit it tomorrow, It was difficult to get the old one of so i imagine putting another back on will be even more harder.
Mozzie
PostPosted: Fri Apr 24, 2015 11:44 am Up
Hi there. just a quick update. I have replaced the gearbox, both front wishbones, and clutch and this car now drives quite good for a 206, just 1 problem though if someone can help?. The rev counter no longer works but it did before the gearbox change, can anyone help?.
