Latest: jackrox1992
Overall: 17186
Online Now [615]:
Visitors: 614
Today: 206300
Total: 147910541
Project sleeper
Go to page Previous  1, 2, 3 ... 71, 72, 73 ... 85, 86, 87  Next
spike_202
PostPosted: Sat Feb 28, 2015 12:45 pm Up
Mine have been in the higher place for 6 years and have had no problems ticking over or revs under 3k so as long as it's mapped right imo you won't notice the change.
**spike's project**
TEAM:+200bhp
PostPosted: Fri Mar 27, 2015 3:39 am Up
A few more changes to the power steering hoses.
PostPosted: Fri Mar 27, 2015 8:53 am Up
I didn't like the old fitting and the hose was a bit messy with original Peugeot pipes joined together with an extension piece. So I bought an alloy PAS fitting from Torques UK and got a hose made up locally with a -6 JIC fitting on it.
The hose goes under the sump now and connects to the original metal pipe.
It's not 100% as I wanted it but it's neater than before. It also does away with the old redundant PAS pressure sensor.
t1mmy
PostPosted: Wed Apr 01, 2015 5:02 pm Up
Looking great as ever, keep up the good work.
PostPosted: Thu Apr 02, 2015 7:00 am Up
Thank you. Car is almost finished now. I think there is a slight leak from the PAS pump still. I might need to buy a seal kit but it's only minor. I think it would fail an MOT for that though. Other than that it needs a set of tyres and it's ready to go.
Andrew
PostPosted: Thu Apr 02, 2015 12:33 pm Up
New PAS pump set up looks great. If you don't mind me asking, could you give me a rough figure on how much it has cost you to source the parts needed to convert? I will need to do this myself at some point
My 206 thread
www.detailedbyandrew.com
PostPosted: Thu Apr 02, 2015 1:39 pm Up
Roughly...pump is about £50, bracket cost £10, latest hose was £20, screw in fitting for the pump was £10, low pressure hose £5. The wiring cost a few quid as I wanted to use the standard Peugeot fuse box so with the high current connector for the pump it was about £35 for the electrics. PAS fluid is £5.
Horton898
PostPosted: Thu Apr 02, 2015 3:22 pm Up
Im pretty new to the forum so I've got a lot of catching up to do but from what I have seen you've got a keen eye for detail, that motor looks incredible!
tRiCk
PostPosted: Mon Apr 13, 2015 5:06 pm Up
Hey Edward, I'm trying to find out what car I can get a solid timing belt tensioner for my ew12, same as ew10 really. Do you have one fitted on your car?
Thanks in advance
drmo
PostPosted: Mon Apr 13, 2015 5:20 pm Up
I think that 1.9d tensioner would do the trick. You just need a stud from dw8 engine, to bolt it to, and that is it. 0820.17 is the part number of the stud for the tensioner.
www.enigma-motorsport.si
www.facebook.com/Enigm.../timeline/
Schumi
PostPosted: Wed Apr 29, 2015 3:31 pm Up
If you need solid tensioner I suggest 306GTI6 ones with early metal tensioners.
2005 206 RC RED
PostPosted: Sat May 23, 2015 2:49 am Up
Spent some more money this month...I can't justify spending on the 206 when I don't get much time to drive it so I bought this. A Trek Domane 4.5 Disc...all carbon fibre, disc brakes, a few bits of Ultegra groupset...it's nice. It would have been far cheaper to get the 206 back on the road that's for sure.
Straight away I changed the monster cassette for one with closer ratios.
macj
PostPosted: Tue May 26, 2015 2:30 pm Up
As always Ed your attention to detail is impressive Thumbs Up
Carlos_WR1
PostPosted: Wed May 27, 2015 11:24 am Up
Nice to see someone else into cars and road bikes like myself (although technically thats a cyclocross) I have just upgraded my bike to a full carbon. Started on a Dedacciai SC61.10A and rode that for 3 years, just replaced it with a 13 Inuition Alpha, have swapped a few components over with it so im running Sram Apex and have FSA KForce Head Stem, SeatPost and Egonomic HandleBars. Ill have to get some pics up.
Have you used the Trek much? where abouts are you based, whats the cycling like around your way?
existenz
PostPosted: Tue Jun 09, 2015 11:19 am Up
Hey Edward, have you driven you car and can give some feedback on your 21mm torsion bars?
I'm running Koni yellow dampers and HR 35mm springs. I use a 24mm rear ARB, but my rear is still rather soft. I would just like to know if its worth the upgrade, as I'm feeling I need that extra stiffness for autocross...
Page 72 of 87
