Latest: lio94
Overall: 17181
Online Now [315]:
Visitors: 315
Today: 64618
Total: 141375322
Forums › The Car › 206 Talk › HID Conversion Kit
HID Conversion Kit
tez_69
PostPosted: Tue Apr 21, 2015 5:12 pm Up
I have recently fitted after-market angel eyes to my Peugeot 206 Verve (06 plate) 1.4 .... I am now wanting to install a HID conversion kit. On all the kits I have researched and installation videos I have watched, they all have 2 wires that connect straight into the factory headlight socket (black and red). However, my headlight socket has got 3 prongs all in a straight line so these kits would not fit directly. Does anyone know how I could connect them?
PostPosted: Tue Apr 21, 2015 5:48 pm Up
You connect the wires which connect to the bulb, not to the headlamp unit itself
Carlos_WR1
PostPosted: Tue Apr 21, 2015 5:51 pm Up
Depends which HID kit his bought, some of them have wires coming off the bulb and those plug in to a connector that runs to the ballast. Potentially youll need to cut the wires and fit connectors if you want to run them through the rubber grommet on the headlight to ensure its water proof.
Ill see if i can get some pics of how i did mine tomorrow.
tez_69
PostPosted: Wed Apr 22, 2015 1:15 pm Up
articles.dashzracing.c...iagram.jpg this is the sort of set up I have been looking at
Carlos_WR1
PostPosted: Wed Apr 22, 2015 2:15 pm Up
Yeah pretty much the same as the kit i fitted in my angel eyes. I didnt get a chance to get a pic tonight, but to explain the way i did it.
I cut the blue and red wires near the the bulb end and rejoined them. Prior to rejoining i pushed the red and blue wires from the plug end through the existing grommet on the angel eye headlights. It was a bit of a job due to the thickness of the wires but a tooth pick helped. once i had pushed the wires through the existing grommet i then rejoined them using male and femail spade connectors.
One of the wires, i think its the red one need to be joind to 2 wires within the headlamp itself.
Ill try and get some pics up tomorrow if i remember but to answer the original post, what you are trying to do can be done as i have done it.
