Online Now [247]:
Visitors: 246
Today: 42356
Total: 142855824
Forums › The Car › 206 Problems › Peugeot 206 gti 180 - Heatshield rattle (Solution)
neoluz
PostPosted: Mon May 04, 2015 1:55 pm Up
Hi,
all of you who have rattle at 3k an so (mostly heard on freeway).
What solved my problem was tightening the screw on the right.
dont mind the oil stains Wink rocker gasket leaking (hope so) Smile
cainw1
PostPosted: Mon May 04, 2015 3:20 pm Up
Interesting post, i am unsure but think i may have a slight rattle. how did you access these bolts to tighten them?
Can you reach them from the engine bay easily?
PostPosted: Mon May 04, 2015 3:48 pm Up
I don't understand,where this bolt is,it would be better to have a better pic to get things clear.
Project2062014
PostPosted: Tue May 05, 2015 5:06 pm Up
Down the back of the engine on the top of the exhaust manifold . There a pain too get to .
neoluz
PostPosted: Wed May 06, 2015 1:01 am Up
first you have to remove engine cover and then access it behind the engine yes.. you will need Gedore or some tool of this kind. Smile it is not that hard to access, just put some gloves on. And i think the bolt is size 12 Smile
Project2062014
PostPosted: Wed May 06, 2015 4:38 am Up
Bolts is a 3/8. might get away with a 10mm
