Online Now [194]:
Visitors: 193
Today: 2791
Total: 138859442
Forums › The Car › 206 Problems › Bit of help on identifying these parts to replace please!
jacktastic1
PostPosted: Mon May 11, 2015 1:35 pm Up
Hey,
I have just upgraded to a faster 1.6 Peugeot 206 Allure edition, now I am looking to get it back into shape as some parts are slightly rusted and just generally clean the car.
My first question, do you know what the specific part would be called for the top of the engine, so the plastic cover? Basically it is the middle part of the engine with 8 screws and the oil cap on.
One of the screw points has cracked and there is now no screw in there as well as the fact there is a reasonably big crack in the plastic. What would this part of the engine be called so I can buy a replacement top? Also is this going to cause any issue driving it around- not sure what a crack in the plastic will do to the engine, bit of an amateur here!
The second part is the brake section of the car. The brakes are new however the part holding the brake pad is very rusty. I want to replace this, more for the look of the car than anything. As I can see it is rusty behind the hubcap. What part of the brakes/behind the hubcap would this specific part be called? It looks like a lump of metal by the brake pad?
Also- would this be expensive to replace/something I could do myself? Or is this a garage job!
Thanks again!
macj
PostPosted: Mon May 11, 2015 1:41 pm Up
1st is called an engine cover or plastic cam cover.
2nd is called a caliper and holds the pads against the disc.... they are not cheap but several people have painted them to improve appearance..... sadly
jacktastic1
PostPosted: Mon May 11, 2015 4:47 pm Up
thank you that is most informative, yes the break calipers were what I was looking for!!
I can see, people think paint is a good idea.. although it may improve the appearance I am seeing online it may erode the break line, so not a good idea by the looks of it!
jacktastic1
PostPosted: Mon May 11, 2015 4:48 pm Up
does anyone know what screws would be needed for the engine cover? I could do with some of them as well as mine are rusty,
thanks
PostPosted: Tue May 12, 2015 12:23 am Up
New screws would be cheap from any Peugeot / Citroen main dealer parts department.
jacktastic1
PostPosted: Thu May 14, 2015 2:48 pm Up
do you know what screwdriver would be required? /the type of screw for the top engine cover?
It is not a phillips unfortunately
Carlos_WR1
PostPosted: Fri May 15, 2015 7:00 am Up
Might be Torx you need to look for.
vanmanpaul83
PostPosted: Fri May 15, 2015 8:16 am Up
The screws for that plastic cover are torx for definate, I have the 1.6 16v xsi. That cover just covers the coil pack and oil breather pipes. Having a crack in that specific piece of plastic will do no harm whatsoever but as you said you want to replace it to make car engine bay look tidy.
**Update**
I've been working on my car this afternoon so I've checked out what size torx bit it is and its a T20 you need Very Happy
jacktastic1
PostPosted: Sat May 16, 2015 9:04 am Up
Thank you, very informative- I had come to the same conclusion! I had just bought a torx screwdriver and replaced it! You are correct, wouldnt affect the engine- so didnt really need replacing annoyingly but hey it makes the engine bay look tidy as you said!
Only thing is the screws are very very rusty. Anyone know what screws are needed to replace them?
I have a feeling these will do?
www.ebay.co.uk/itm/300...EBIDX%3AIT
