Latest: Beduff1977
Overall: 17134
Online Now [199]:
Visitors: 198
Today: 25139
Total: 107130618
Forums › The Car › 206 Talk › A front grill question
MrMac
PostPosted: Sat May 23, 2015 7:50 am Up
More questions. Can I change the front grill bumper (black bit) for a newer type? So the line kind as below.
www.ebay.co.uk/itm/Peu...2ee188cd3b
To the honey comb style, as below
www.ebay.co.uk/itm/PEU...35eab5e02b
One last thing. Is it easy to change the petrol cap from the nomal colour coded to the GTI/CC silver type, but keep the same key and lock.
PostPosted: Sat May 23, 2015 10:08 am Up
If you swap non-sport for non-sport or sport for sport then I don't see why not.
To change the cap, take the cap off, leave the key in and the coloured part just twists off. 30 seconds of a job
Carlos_WR1
PostPosted: Sat May 23, 2015 10:13 am Up
Hi, changing the grill from the one you have to the honey comb grill is a fairly easy swap and provided you get the right grill as there are 2 shapes of front grill depending on the model of car. for example the grill on my GTI is different to the 2 you have linked to, mine is deeper and has a step in the bottom that fits around the number plate.
If you grill is the same shape as the 2 you have linked 2 and you are thinking of buying the second grill, its an easy swap although to do a proper job youll want to take the front bumper off. there are likely to be 2 10mm bolts under the front of the car, youll then need to take the wheel arch liners out and youll find 2 more 10mm bolts, one on each arch as it joins to the bumper.
The GTI fuel cap cover is a cover so you should be able to buy one and fit it easy to your existing fuel cap and keep your existing locks. Like this one for example:
www.ebay.co.uk/itm/PEU...567520fe76
MrMac
PostPosted: Sat May 23, 2015 11:09 am Up
Cheers chaps...appreciate it.
