Latest: Kifi69
Overall: 17183
Online Now [475]:
Visitors: 474
Today: 67386
Total: 144887648
Project sleeper
Go to page Previous  1, 2, 3 ... 72, 73, 74 ... 85, 86, 87  Next
drmo
PostPosted: Tue Jun 09, 2015 12:09 pm Up
Existenz, change the crapy koni dampers for some bilies. The difference is enormous.
www.enigma-motorsport.si
www.facebook.com/Enigm.../timeline/
existenz
PostPosted: Tue Jun 09, 2015 7:07 pm Up
I'm really happy with them for what they are Wink
drmo
PostPosted: Wed Jun 10, 2015 6:56 am Up
Very Happy
Don't know why you are complaining on the soft rear then, if you are so satisfied. Laughing With bilies it is a whole different car Wink
Ask forum member =ZiAn= about the 21mm torsion bars. He has 21mm torsion bars and he tracked the car, so could probably told you how the car handles and how big of a difference it is. He has bilies also.
Here is his topic:
www.206info.co.uk/Foru...t=418.html
PostPosted: Wed Jun 10, 2015 8:28 am Up
Dampers don't control pitching under braking and acceleration. 21mm bars are fine for road use especially with a bigger rear ARB.
drmo
PostPosted: Wed Jun 10, 2015 9:12 am Up
You would be surprised. Smile
PostPosted: Wed Jun 10, 2015 11:24 am Up
They delay the movement or slow it down but that's all. They don't reduce body roll once settled into a corner either.
existenz
PostPosted: Wed Jun 10, 2015 1:20 pm Up
The front is just fine. But under acceleration and tight corners with bumps and some uphill parts I always feel (and see on photos) that the rear really need some stiffer torsion bars, as a large part of the wheel diesappears under the arches. And I think 21mm might be the way to go with my setup, unless I am going for Grp N Bilsteins or something of that sort. It should greatly improve acceleration, especially in combination with the Quaife ATB.
drmo
PostPosted: Thu Jun 11, 2015 3:12 am Up
I'm not denying that larger diameter torsion bars won't help, I always encourage people to go stiffer if they have changed front springs, but the dampers play a huge role here, and driving both koni and bilstein equiped cars, I can say that over bumps and turn-in, the bilies are in a whole different league.
Be careful when choosing the rear torsion bar/arb combination. Our experience is that when you go over 21mm torsion bars and 24+mm arb, the rear inside wheel always tends to loose contact and lock under braking. Torsion beam in this matter is really tricky.
I disadvise Quaife ATB in any form of motorsport. Maybe some people can sense the difference, but with fitting this ATB to many cars, and driving them, I can honestly say that it is not worth the money. There is so little difference, if any at all (it also depends a little on the suspension setup), that in my opinion it is money thrown away. Better to put money in sorting the suspension properly (camber/caster top mounts and suspension bushings etc.).
This ATB is not a real torsen diff, well it doesn't act like it. Try a Honda Civic with OEM Honda torsen diff and a civic with Quaife ATB. You won't believe that both are torsen. The oem one acts more like a plate diff when mid corner accelerating, and that is how it should be, while the Quaife is more like open diff. I was really disappointed when I first tested it and since then, every car we put it in didn't feel anything like it's supposed to be. Don't get me wrong, the quality of manufacturing is really good compared to others, it always fits like an oem part, but for less money you can get a plated diff from Gripper, which also has a lifetime warranty and does its job. It doesn't fit without a hassle though, in any gearbox that we fitted (BE,MA,JC5,...) Laughing
existenz
PostPosted: Thu Jun 11, 2015 4:48 am Up
As I said it works good. It's still a street car. In case I go for a new suspension setup, I'd go for a race suspension anyway. I'd love to go for 22mm bars, but that would be too much for the front springs I guess. So I think 21mm is a good compromise.
But right now, I am simply looking for a way to make my rear stiffer Smile
spike_202
PostPosted: Tue Jun 23, 2015 4:42 pm Up
Edward wrote:
The blue covers? Yes they came with them.
Back together now...forgot the big washers at the top of the damper under the top mount...so it's all coming apart again.
Bit stage as this. When I removed all my strut setup to replace the springs my washer was under my BIG nut on the top side of the top mount? So is your nut just onto the top mount with no washer?
**spike's project**
TEAM:+200bhp
PostPosted: Wed Jun 24, 2015 1:47 am Up
I think there are two washers. One below and above the top mount beneath the nut.
spike_202
PostPosted: Wed Jun 24, 2015 9:03 am Up
I think so mate
Just been down to the pug garage on me dinner and orderd 2new top and 2new bottom washers and 6new top mount bolts. But they've got to do some ringing around as they don't stock them and come in packs of 20.
70
71
73
**spike's project**
TEAM:+200bhp
spike_202
PostPosted: Wed Jun 24, 2015 9:07 am Up
Another thing I was going to ask was with the b8 dampers being a short shaft did you have to get a shorter profile spring? Or would my new pro lines fit straight onto the b8? Although my b6's went any way near as bad as yours I'd still like to change them in a year or so.
**spike's project**
TEAM:+200bhp
PostPosted: Wed Jun 24, 2015 11:36 am Up
The shorter damper internals just mean the car can be lowered without the dampers bottoming out as easily. Bumps stops on these dampers are internal unlike most dampers which use a big rubber external Bumpstop.
spike_202
PostPosted: Wed Jun 24, 2015 11:49 am Up
Got ya. so it's nothing to do with the physical size of the shock. Just alows you to go lower if you need to.
**spike's project**
TEAM:+200bhp
Page 73 of 87
