Latest: Kifi69
Overall: 17183
Online Now [398]:
Visitors: 397
Today: 149634
Total: 143809720
Forums › The Car › 206 Problems › Please help!!!! P0110 and P0141 - what should I change?!
dmsempire
PostPosted: Tue Jun 16, 2015 8:31 am Up
Hi everyone, I just had my codes read and the only ones that come up are P0110 and P0141, also there is a spike in fuel consumption and a smell of petrol coming out of my exhaust along with black smoke sometimes, also I have a fluctuating idle, I just had the idle valve cleaned, but doesn't do anything. I did take the Sparks out and seems they are due for a change, so will do that later this week, but can anyone tell me what sensors I should change for th two codes provided. Thank you in advance.
dmsempire
PostPosted: Tue Jun 16, 2015 8:34 am Up
Forgot to add the car, it's a Peugeot 206, 51 plate, 1.1 8v look model.
PostPosted: Tue Jun 16, 2015 9:49 am Up
P0110 Intake Air Temperature Circuit Malfunction
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
Second one could be caused by the first 1 as unburnt fuel will be passing over the sensor. Did you clean the MAP sensor as this contains the air temp sensor and ultimately determines how much fuel to put in the cylinder
dmsempire
PostPosted: Tue Jun 16, 2015 10:31 am Up
thank you for replying, I did clean the map sensor and the whole air intake as I found a guide on here, you think I should replace it?
dmsempire
PostPosted: Thu Jun 18, 2015 1:18 pm Up
Which O2 sensor should I change in case the map sensor change doesn't resolve the issue? The before cat one or the after cat one? Thank you.
dmsempire
PostPosted: Fri Jun 19, 2015 9:49 am Up
Changed the map sensor, no change in errors, should I go ahead and change the other ones or is it something elsE?
dmsempire
PostPosted: Fri Jun 19, 2015 11:34 am Up
Drove it, erased the errors and the light is off now, dont know how exactly cause I didn't turn it off as I don't have that tool, I only have a normal obd reader, didn't give me the errors again though, but still the petrol smell persists, what could it be?
dmsempire
PostPosted: Fri Jun 19, 2015 2:09 pm Up
No one? Btw the light is back on.
sloposse
PostPosted: Fri Jun 19, 2015 5:23 pm Up
smell of petrol can only mean one thing its not being burnt, does it drive ok?
If you can smell petrol through a catalytic converter, the cat is soaking up the petrol and is slowly destroying it not only that when it reaches normal temperature it burns away and all the bits that are left fall apart and block up the exhaust.
dmsempire
PostPosted: Sat Jun 20, 2015 2:15 am Up
So what should I do? What to change or what to clean? Thank you.
