Latest: Kifi69
Overall: 17183
Online Now [551]:
Visitors: 550
Today: 51899
Total: 144343476
Forums › The Car › 206 Problems › Removing intake manifold and throttle body [gti 180]
existenz
PostPosted: Tue Jul 07, 2015 3:03 pm Up
Hi everyone,
I'm about to remove the intake manifold and throttle body to clean and paint them.
I want to remove all bolts of the intake manifold and pull it out without removing/moving the radiator. So I'd like to know if this is possible this way and what is the cleanest method to remove the injectors?
Thank you
cainw1
PostPosted: Tue Jul 07, 2015 3:19 pm Up
I'd be quite interested to know if this is possible too. Thanks to anyone who knows
PostPosted: Tue Jul 07, 2015 5:02 pm Up
Yes it can be removed without removing the radiator, just be careful you don't puncture it as you remove it, and watch the pipe that goes to the dump as well.
And in regards to the injectors disconnect the fuel line, and don't tip it the wrong way before you can get it over a container to drain it.
existenz
PostPosted: Tue Jul 07, 2015 6:29 pm Up
Thanks for your reply. What dump?
How much ml of fuel can I expect comming out of the line? I read removing the fuse of the fuel pump with a running engine will avoid any leaking.
PostPosted: Wed Jul 08, 2015 1:52 am Up
Just leave it an hour before removing any fuel hose and the pressure will have reduced. Get a cloth to capture any spillage when the hose is removed from the fuel rail.
It might be easier to access some of the bolts from underneath the car.
existenz
PostPosted: Wed Jul 08, 2015 2:27 pm Up
Thanks for your help Edward.
existenz
PostPosted: Fri Jul 10, 2015 7:04 pm Up
Just one more question. The studs (no 3 in the picture) are easy to remove? Don't want to break them :S
PostPosted: Sat Jul 11, 2015 2:01 am Up
Should be easy with the right torx socket. Mine come out easily.
existenz
PostPosted: Sat Jul 11, 2015 4:54 am Up
I'm covered with tools. Should be no problem.
Thx !
existenz
PostPosted: Mon Jul 20, 2015 7:59 am Up
Throttle body is removed and the intake manifold is loose, but I still can't remove it. Still attached to some wires/hoses. Got to look from underneath the car.
existenz
PostPosted: Mon Jul 20, 2015 1:09 pm Up
Was still attached to that oil hose... and it was really difficult to get the manifold out, especially with my aftermarket radiator.
But it's out - yay
existenz
PostPosted: Thu Jul 23, 2015 2:33 pm Up
Here for you guys
