Online Now [181]:
Visitors: 180
Today: 88603
Total: 143397493
Forums › The Car › 206 Problems › Cooling fan not comming on
smokey
PostPosted: Fri Jul 17, 2015 12:32 pm Up
I've just found out my cooling fan dies not kick in to keep the car from over heating.
To make this a short as possible, I've looked on the forums and eliminate the problem down to a corroded wire.
Question is do I just go to the scrap yard and find the terminal block and cut it off and crimp it to the wires I still have?
I do have a photo but don't know if I can attach it
PostPosted: Fri Jul 17, 2015 1:33 pm Up
Just replace it with new wiring and terminals.
PostPosted: Fri Jul 17, 2015 1:45 pm Up
I just got a new cooling fan loom from the very early 206, a bit of soldering & heatshrink action later resulted in having a working cooling fan again.
This was before I finished of the job & covered it back up with the plastic protective conduit.
smokey
s51.photobucket.com/us...img]Surely this is a whole loom, as it is the two relays that control the fan for both the A/C and the cooling of the rad?
