Online Now [223]:
Visitors: 222
Today: 4245
Total: 142817774
Forums › The Car › 206 Talk › Oil change now engine a bit tappy
greenpug2222
PostPosted: Wed Jul 22, 2015 12:53 pm Up
Hi,
I've just completed an oil and filter change and decided to go for 5w40 instead of my norm 10w40. However now it's running a bit tappy...... Is this ok as I e never used 5w40 before?
why wont you work??????????????????? ARGH F**k it!!!!!
Sim
PostPosted: Wed Jul 22, 2015 1:00 pm Up
Double check dip stick level, run about, and check again until it settles
On a 2000 2.0 HDi I switched to 5w40 during winter, and I think I'll stick with it now, no tapping. It's supposed to be more liquid when cold than 10w (hence the lower number 5w), maybe you hear tapping on your engine.
I used to record the before and after oil change engine sound Very Happy but never analysed those videos, as simply the difference was ever so faint
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
greenpug2222
PostPosted: Wed Jul 22, 2015 1:19 pm Up
Ive checked and run about and re checked levels and they are fine. The engine sound is a bit tappy.... Could this just be cause it's a "thinner" oil?
Ste
PostPosted: Wed Jul 22, 2015 2:05 pm Up
Staff - Ste
If it's a high miler, use a thicker oil, rather than a thinner oil..
The Cars:
greenpug2222
PostPosted: Wed Jul 22, 2015 2:31 pm Up
It's on approx 144 thousand. I'll run it tonight and tomorrow morning..., if no change I'll put 10w40 back in.
Pity they don't do a fully synthetic 10w40
greenpug2222
PostPosted: Mon Jul 27, 2015 7:20 am Up
I decided to stick it out and the noise has now almost gone. No idea why .
I can report that the car is a bit more .... Let say eager than normal.
