Latest: SA01
Overall: 17138
Online Now [355]:
Visitors: 354
Today: 23263
Total: 112247718
Forums › The Car › 206 Talk › HELP!!!! Urgent breakdown help needed
HowlingMadMurdock
PostPosted: Fri Jul 24, 2015 2:05 pm Up
This evening I hit a pothole on a country lane, it was quite a bump.
The STOP light came on in the speedo and the car ground to a halt.
It's a 2000 model 1.4LX.
I turned it over several times and whilst it turns it won't fire and the STOP light is on. It's been running like a dream up to this point.
Usual things were fine, plenty of fuel (I'd just put £15 in), oil level fine, no hiccups until I hit that pothole.
The nearside tyre was deflating as I left it, looks like a puncture so I'm expecting it to be flat when I get back to it. It has non-standard allows on so I can't see it having any kind of tyre pressure sensor on it.
It wasn't the worst pothole I've hit but it was a quite deep one.
I have a suspicion it's knocked out some kind of electrical item causing the STOP light to come on. It's a pre-plex model so no codes to display etc.
Any ideas as to a possible cause or common failures of this type?
I'm waiting to hear from my local garage to see if they can recover it and fix it this weekend (out of hours now sadly) and fortunately Tony will do it on the slate if need be but if there's an easy fix I'll go get it sorted myself.
I ain't nuts, I'm condiments, I've been promoted
PostPosted: Fri Jul 24, 2015 2:36 pm Up
Being prep plex it should have the emergency cut off button under the bonnet, chances are if you've had enough of a bang its triggered that and just needs resetting.
mattymj
PostPosted: Fri Jul 24, 2015 2:42 pm Up
Maybe a broken earth lead under the battery tray?!
HowlingMadMurdock
PostPosted: Fri Jul 24, 2015 2:58 pm Up
Thanks Lee, I'm onto that one and will have that checked out. The tyre is going down too so I'll get a lift up there tomorrow with the spare battery and a compressor and try my look.
Matty, all electrics seem fine. Everything works but it's like there's no fuel and the STOP light is constantly on. I'm hoping the STOP solenoid hasn't gone, I had that happen on a wagon but with that it was the start solenoid, they had start and stop solenoid on the old MAN 7.5 tonners. The start solenoid went so ironically you could could start the thing but you had to stall it to stop the engine
Sim
PostPosted: Fri Jul 24, 2015 3:21 pm Up
Like LeeThr said, it must be an emergency fuel-cut-off impact sensor.
Found from the internetz:
Quote::
The inertia fuel cut off switch is located on the nearside, between the suspension top mounting and the bulk head in the engine bay, it has either a black or red rubber top, looks similar to a top hat.
To reset it, you press the top down (rubber circular bit), if it has been activated, it should click slightly when you press it, the engine should then start when you try it again.
Haha it was MrWhite that during pugfest showed this to me on my year 2000 HDi pug, many thanks to him!
Good luck!
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
HowlingMadMurdock
PostPosted: Fri Jul 24, 2015 4:10 pm Up
Cheers Sim Smile
HowlingMadMurdock
PostPosted: Sun Jul 26, 2015 9:30 am Up
Thanks guys. Got a lift back to the car with my mate who's a biker, pressed the fuel inertia switch, and she fired up instantly.
My mate laughed like hell but said in all honesty he wouldn't have thought it.
It's not just me this will happen to so hopefully people will be aware of this in future
MrWhite
PostPosted: Tue Jul 28, 2015 11:50 am Up
Good to hear Mateys ^_^
My 206 Project Thread
