Latest: Stu-mill
Overall: 17131
Online Now [319]:
Visitors: 319
Today: 95986
Total: 104781530
Forums › Tuning, Modification & Legal › Project Cars › Le Bebé GTI180/RC
Le Bebé GTI180/RC
Go to page Previous  1, 2, 3
PostPosted: Mon Jan 05, 2015 8:47 am Up
I wouldn't block any passages in the head as they could interfere with any contraction or expansion of the head as it cools and heats up.
America
PostPosted: Wed Jan 07, 2015 3:23 am Up
Good point...
lrc_toto
PostPosted: Thu Jul 23, 2015 7:04 pm Up
Update:
I bought myself some semi-slicks.
Toyo R1Rs. Cool
4-piston Brembos from a V6 406:
I really like how they turned out. Some serious stopping power!! ATE disks, ATE pads, Motul Racing 660 brake fluid and stainless steel braided brake lines. 15mm spacers up front. Very Happy
Also, dropped the height of the rear axle. That really helped balance the car. Next to a mate's 200bhp GTI-6 306 and a V6 405 Very Happy
Sadly, I encountered some serious problems with the suspension at this year's Pug Fest. The car was very unpredictable both on and off-throttle. Turned out to be one of the front KW's Shocked :
I am currently running stock front shocks with Eibach springs:
Fixed the intake. This actually made a noticeable difference in acceleration as the engine is finally sucking some colder air.
Twisted Evil Twisted Evil Twisted Evil Twisted Evil Twisted Evil
Next on the list:
Front suspension Rolling Eyes
Shorter final drive. I already have it, just need to find the time to assemble the new gearbox. Smile
Some heat management. Custom front mask. There is a lot of heat in the engine compartment. Replacing the battery with a lightweight one. Larger custom aluminum radiator.
LSD
Enabling the LC Twisted Evil
GTI UN JOUR.. GTI TOUJOURS.
Sim
PostPosted: Sat Jul 25, 2015 4:20 am Up
That some car pron mate! Those calipers... Nom Nom Droolage!
How big are the disks? Heard from pro_steve one can fit 307's 302mm disks and calipers just under 16in wheels (skin of teeth of space left really, but fits!)
Here's a photo
But these look not as big however 4 piston must grip like hell!
Pity we didn't catch up during pugfest, where in the world are you based? Very Happy
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
lrc_toto
PostPosted: Sat Jul 25, 2015 5:13 pm Up
The disks are 288mm if I remember correctly.
Actually the piston surface of the 4-piston callipers is a lot bigger than the stock 2-piston callipers. Add the ATE disks and pads, the stainless steel braided brake lines and the Motul brake fluid and you will notice a significantly better brake performance compared to the stock brakes.
They squeak a lot though. Embarassed Very Happy
When I approach a bus stop and apply even the slightest pressure on the brake pedal it's like a train stopping. Most people on the bus stop get frustrated or scared. Laughing
I live in Sofia, Bulgaria. Wink
Btw, I made a small mistake in my previous post - the spacers are 15mm. The 13mm ones didn't clear the stock wheels.
Sim
PostPosted: Sat Jul 25, 2015 7:06 pm Up
Fair play mate Smile Interesting to know hmm maybe they'll bed in a bit and squeak less? Awesome macro picture of more car pron from your first post!
Sofia, BG, so it says your location, for whatever weirdest reasons I thought your licence plate is French (closer look does say BG lol), your english is better than of a native speakers and pugfest was just in UK, so I got confused as to where you're from lol
EV
GTC VXR (sold)
existenz
PostPosted: Sat Aug 01, 2015 6:10 am Up
Nice progress mate.
The compbrake mounts fit the Eibach just fine? They look rather thick, so I imagine they might affect the ride height?
I'm thinking about the Brembo from the V6 as well (running 15' Ultras offset 18 - the fit without spacers afaik). The 288 discs are the best option in regards to noise, 283 are worse. Do you run standard 22.2 master cylinder?
lrc_toto
PostPosted: Sat Oct 24, 2015 9:08 am Up
I am using the stock shocks with Eibach springs. I removed the top mounts with the KW's.
Standard master cylinder for now.
Thinking of swapping the standard GTI138 oil pan and sump for the GTI180/RC one?? Any recommendations?
Page 3 of 3
