Online Now [1441]:
Visitors: 1440
Today: 93395
Total: 149168363
Forums › The Car › 206 Problems › fault code 1327
fault code 1327
gibbo300
PostPosted: Tue Jul 14, 2015 5:22 am Up
206 52 plate 1.1. got a non start problem with fault code 1327 phase detection sensor or circuit. anyone got any ideas?
PostPosted: Tue Jul 14, 2015 6:39 am Up
Poor or worn plugs. Possibly NGK fitted. Possibly knackered coil pack
gibbo300
PostPosted: Fri Jul 17, 2015 11:42 am Up
not firing at all so deffo not plugs, coil pack or CAS ????
gibbo300
PostPosted: Fri Aug 14, 2015 6:18 am Up
is there really nobody on here with any ideas?????????
Sleepy-Gti6
PostPosted: Fri Aug 14, 2015 12:24 pm Up
Have you got power at the coil pack? If you have, then it could be a faulty coil pack itself. Have you tried a different one?
If you haven't got power there, chase it back and find out where its going.
***disclaimer*** I've never owned a 1.1 TU-series engine, and have very little knowledge of them, so i'm sorry if these suggestions are wild.
sean.r.steward
PostPosted: Sat Aug 15, 2015 12:31 pm Up
has know one on here mentioned it maybe a crank sensor issue.
what's the code definition?
gibbo300
PostPosted: Mon Aug 24, 2015 4:23 am Up
1327 code. phase detection sensor or circuit
gibbo300
PostPosted: Tue Aug 25, 2015 10:44 am Up
McGuiverNL
PostPosted: Tue Aug 25, 2015 11:17 am Up
Could be crank sensor indeed...
Anything that gives the ECU information about the engine's firing cycle which if giving poor signal makes the data it receives unclear and can send the ECU into safety mode (maybe cut fuel or spark to a cyclinder).
Poor or interrupted current flow (Earth strap/sensor/connector/faulty or sparking to surrounding block coilpack) seem likely...
2005 LHD black RC (GTi180)
gibbo300
PostPosted: Mon Sep 14, 2015 4:53 am Up
I have tried the pp2000 program and it confirms the phase detection integrated into ignition and it also shows the ecu is locked and that no keys are synchronised. any ideas on this anyone. I must say that its my first time using pp2000 so not sure what I am doing really. I assume the immobiliser is not unlocking the ecu and allowing the engine to fire and run ?
