Latest: S2cgm
Overall: 17178
Online Now [122]:
Visitors: 122
Today: 2093
Total: 137069353
Forums › The Car › 206 Talk › 206 gti 138 front callipers on a 2.0 hdi
Imelliot
PostPosted: Fri Sep 04, 2015 9:21 am Up
Got some gti 138 calipers for my 2.0 hdi are they a direct fit? Anything i should know? Got the new discs there as well
PostPosted: Fri Sep 04, 2015 11:18 am Up
Aren't they exactly the same as the ones already fitted?
Imelliot
PostPosted: Fri Sep 04, 2015 11:20 am Up
Nope they're bigger
PostPosted: Fri Sep 04, 2015 12:20 pm Up
You 100% sure of that?
Imelliot
PostPosted: Fri Sep 04, 2015 12:22 pm Up
Yep they're wider so is the discs. Guy I got them from said it was the gti 130 ones he got them for his saxo. But definitely bigger
PostPosted: Fri Sep 04, 2015 12:34 pm Up
What's wider? So is discs? A quick look on Euro Car Parts only lists 266 mm discs for the 2.0 hdi
Imelliot
PostPosted: Fri Sep 04, 2015 12:38 pm Up
The discs are slightly bigger and the callipers are 110% bigger not by much though. Could be possible they're off a 180?
PostPosted: Fri Sep 04, 2015 1:17 pm Up
If both are 266 mm then the only difference will be due to later built cars using a slightly wider 266 mm disc which is common to both models.
