Latest: Beduff1977
Overall: 17134
Online Now [476]:
Visitors: 475
Today: 101646
Total: 109272336
Forums › The Car › 206 Talk › Power steering flush & refill
PhotonicDreamer
PostPosted: Fri Oct 02, 2015 6:33 pm Up
Hi guys,
what's the best way to flush the power steering fluid and refill on the 1.1?
cheers!
PostPosted: Sat Oct 03, 2015 12:46 pm Up
Could remove the pressure sensor and see what drains out.
