Latest: Stu-mill
Overall: 17131
Online Now [167]:
Visitors: 166
Today: 16116
Total: 104903714
Forums › The Car › 206 Talk › Power steering flush & refill
PhotonicDreamer
PostPosted: Fri Oct 02, 2015 6:33 pm Up
Hi guys,
what's the best way to flush the power steering fluid and refill on the 1.1?
cheers!
PostPosted: Sat Oct 03, 2015 12:46 pm Up
Could remove the pressure sensor and see what drains out.
