Online Now [302]:
Visitors: 301
Today: 104686
Total: 142248805
Forums › The Car › 206 Problems › Abs and fuel gauge not working when engine running
jeromecqy
PostPosted: Sun Oct 18, 2015 10:16 am Up
wonder if anyone can help me with my Peugeot 206
to keep it simple
I have an old peugeot 206 1.4, now fitted with a 1.6 engine from 206cc, fitted with new axle too
now i am having abs problem
Rear right and left coherence, live data shows 0 kph when driving(engine starting) and shows exact speed when car is not started(Ignition On)
Problem would happen when car is started
What i have done:
- Check wire Harness-OK( Good from abs sensor to abs pump)
- Change New ABS Sensors -DONE
- reluctor Ring- Checked( looks New)
- Connect Rear ABS sensor to front wiring:result :no signal
- Connect Front ABS sensor to Rear wiring:result: measures front sensor speed just fine
BTW front and rear sensor are different
The thing about the fuel gauge is that when i hook up with pp2000 and observe the FUEL LEVEL MEASURED, it spikes up for 15 liter when ever i start the car EXAMPLE: when ignition is on the fuel level measure show 5 liter and when the car is started it shows 20 liter causing my fuel level display to show incorrect levels.
Both car are mutiplexed:
-Donor(206cc year 2003 1.6)
-Original( 206 year 2006 1.4)
My thought is over voltage but i think it could be that
What are your thought and suggestion for me to do?
thanks in advance.
youtu.be/IRyPbkhDxX4
youtu.be/Js7pjHKgVj8
jeromecqy
PostPosted: Tue Oct 20, 2015 2:38 pm Up
BUMP
jeromecqy
PostPosted: Thu Oct 22, 2015 3:24 am Up
BUMP
PostPosted: Thu Oct 22, 2015 5:23 pm Up
I take it the BSI from the CC has been used? Have you reconfiqured it to suit the hatches needs?
The ABS sensor problem sounds similar to an ECU failure i had on a 206 before, what faults are in the system?
jeromecqy
PostPosted: Fri Oct 23, 2015 4:56 am Up
coherence
See video for an understanding
i have reconfigurate the BSI for hatch use
engine ECU failure?
but it is sensing while car is no started so how is it a failure?
PostPosted: Fri Oct 23, 2015 8:18 am Up
What about the instrument cluster, have you changed that?
And no, ABS ecu failure
jeromecqy
PostPosted: Fri Oct 23, 2015 10:16 am Up
yes i did change the instrument cluster too
so you think it could be an abs ecu failure?
jeromecqy
PostPosted: Sun Oct 25, 2015 10:23 am Up
BUMP
PostPosted: Sun Oct 25, 2015 2:16 pm Up
Have you scoped the sensors? Checked the pins? Check the wiring resistance?
Chances are yes though.
Have you removed the fuel pump and moved the float and checked the level in pp2000?
jeromecqy
PostPosted: Mon Oct 26, 2015 4:25 am Up
i have checked the abs sensor, they are new though, i didn't have a proper scope so i only used a multimeter to test the resistance and alternating current which is showing working digits
no i did not take out the fuel pump and move the float to test because the fuel level is not a very major problem it still can give estimate readings and i can always refer to my trip meter taking it out just to test it is a hassle i want to avoid
but abs light is pretty annoying on the dash and its important on dangerous situations.
jeromecqy
PostPosted: Sat Oct 31, 2015 10:31 am Up
BUMP
jeromecqy
PostPosted: Thu Nov 05, 2015 6:09 am Up
BUMP
PostPosted: Thu Nov 05, 2015 8:25 am Up
You havent done all the checks i said to do....
jeromecqy
PostPosted: Fri Nov 06, 2015 3:02 am Up
i am actually more concerned with the abs
i dont want to ruin the fuel pump by taking it out without the proper tools if i was to open i would use a hammer and some screw driver which would probably spoil the top piece as i said it was not a major issue i am having i can refer to the trip meter to check.
if you wanted me to check the abs sensor or anything please detail it
i have checked:
-wiring from abs sensor to abs pump
- resistance of abs sensor
- AC Current of abs sensor when tire spinning
-readings on PP2000 when tire spinning( result can refer to video ) it fails when engine starts
any thing else i can check?
jeromecqy
PostPosted: Sun Nov 15, 2015 3:54 am Up
Bump.......
