Latest: jackrox1992
Overall: 17186
Online Now [718]:
Visitors: 717
Today: 181541
Total: 148704207
Forums › The Car › 206 Talk › ppt40
ppt40
Forum Index › 206 Talk
steviebee
PostPosted: Fri Nov 27, 2015 1:02 pm Up
Did all plex Gti's have the ppt40 MFD fitted as standard?
frenchie steve
steviebee
PostPosted: Sat Dec 05, 2015 7:20 am Up
Fitted the MFD (ppt40) on Thursday, but due to work only just checked all functions. Poked a coctail stick down the window wiper stalk and all works so no need to be activated in the BSI. Just need to get hold of a Comms 2000 unit with the push button on the windscreen wiper stalk. So if anyone has a broken one and the price is good I might be interested. I can get a 207 one for £30 and as I only need the bit on the end not worried about whether the rest works or not.
frenchie steve
gazza82
PostPosted: Mon Dec 07, 2015 2:50 pm Up
Just did same on the hdi ... New MFD looks so much better. Need to update bsi and sort out stalk now.
steviebee
PostPosted: Tue Dec 08, 2015 2:38 am Up
Hi Gazza, what year is your HDi. Mine is 2005 (2.0) and it dont need updateing. I have to get the stalk though. Have you tried prizing the little cap off the end off the stalk and poking a coctail stick in. I did mine and it came up 47.7 MPG. Did not think that was bad as been giving it a few blasts up the M2 and it does a lot of town work.
Steve.
frenchie steve
gazza82
PostPosted: Tue Dec 08, 2015 3:21 pm Up
2002.
I was going to ask how the end button came out. Then I can try the other functions. Does it simply 'pop' out using a thin blade or screw-fit?
Not showing the temp yet so may have to play but it hss taken over the open door signal just plugging it in.
steviebee
PostPosted: Wed Dec 09, 2015 2:50 am Up
Hi Gazza, yes it should just prise off with a thin screwdriver. You should then see a tiny hole inside. This is where you poke the coctail stick. Good luck! I hope I will be able to just use the end of the stalk on mine, as in picteure on first post saves stripping the steering wheel off. Keep us posted.
frenchie steve
gazza82
PostPosted: Wed Dec 09, 2015 11:47 am Up
I'll give that a try .. I assume it will go back until I find a button (if you find two let me know! Smile )
gazza82
PostPosted: Wed Dec 09, 2015 2:50 pm Up
Well button refused to budge and wasn't willing to force it and break the stalk or button.
And I've got a permanent fault on the temp sender, which might be because it's a Style and doesn't have electric door mirrors ..
Still I have a nicer MFD ..
steviebee
PostPosted: Thu Dec 10, 2015 3:04 am Up
Thats such a shame, but as you say a nicer MFD. The outside temp sensor is on the passenger door mirror, but you probably already know that. Is the wiring there for electric mirrors? If so might just be a case of changing the mirrors. I suppose it all depends on how long you intend to kep the car. Had ours 4 years now, and only just getting around to doing bits to it. I was going to get a 207 sport, but I would have to put about £3K to it to get a 2-3 year newer one with twice the mileage. Ours has only done 74K miles and bodywork very good still.
frenchie steve
gazza82
PostPosted: Thu Dec 10, 2015 8:05 am Up
Haven't had the internal cover off yetto check wiring but will.soon. Also swapping out a n/s mirror on the CC so may check the sender with that one at some stage. Got to finish the Alfa first ...
steviebee
PostPosted: Thu Dec 10, 2015 8:09 am Up
Ok, good luck with it and hope you get it sorted.
frenchie steve
steviebee
PostPosted: Sat Jul 30, 2016 6:37 pm Up
Well have not done much to the pug as have been concentrating on my Transit camper. I have a complete Dav Comms 2000 unit. The one on my pug is a Delphi. Would this be a straight swap or would it have to be set up on Peugeot Planet? Or would I need a Delphi Comms 2000?
frenchie steve
steviebee
PostPosted: Fri Aug 12, 2016 6:56 am Up
Anybody have the answer to this question on the Dav comms 2000 unit?????
frenchie steve
