Latest: lio94
Overall: 17181
Online Now [486]:
Visitors: 485
Today: 66205
Total: 141820763
Forums › The Car › 206 Problems › MFD garbled screen?
MFD garbled screen?
panther12
PostPosted: Tue Dec 22, 2015 5:43 am Up
I have a 2005 206 1.1 which doesn't get used much. I started it up yesterday for the 1st time in a few weeks (starts 1st turn of key). I left it idling for a while to defog windows and the multifunction display screen was working perfectly but when I came back to car the MFD was all garbled and missing some of the characters. Gave it a tap and ign off-on a few times but still a scrambled screen. Was going to have a look at it today but it's working perfect again. Just wondered if the intermittent working / not working is a sign that it's about to go and I need to look out for another one?
PostPosted: Wed Dec 23, 2015 10:25 am Up
That happen because it's not used much,and because of cold weather,if it's a daily use,then it will be good.
gazza82
PostPosted: Thu Dec 24, 2015 4:53 am Up
You might find one or more of the connection pins have come loose where the two circuit boards join. It isn't hard to open up and remove the boards and a quick dab of solder fixed ours ... did it about two years ago and still working fine.
