Latest: Kifi69
Overall: 17183
Online Now [381]:
Visitors: 380
Today: 77614
Total: 143495290
Forums › The Car › 206 Problems › Electric window..
Electric window..
Go to page Previous  1, 2
B1gM4c
PostPosted: Sat Feb 11, 2012 3:26 am Up
Sorry, my son has posted this message. What he has failed to mention is that the cars battery was not disconnected/connected correctly and the car may have a BSI issue? We have checked fuses and believe I can hear relays clicking etc. We have tried the software reboot but didnt work although I am going to try again once the weather gets a bit warmer later today. I do have an OBDII scanner which I need to get from my son in law, do you think this will highlight what is causing the electrical issues? Thanks for your help in advance....frustrated dad!!
Lovepeugeot
PostPosted: Fri Dec 25, 2015 8:57 am Up
Hi I've had a drink spill in the part which controls window passenger side works fine drivers side goes up n down on its own n is now stuck half open lucky I have a private drive to park it on or I'd of woken to no car great Christmas that would of been Lool
Anyone out here that can hel me sort this problem as I'm meant to be visiting family and friends over the festive season but now can't leave car unattended
Merry Christmas everybody
Sim
PostPosted: Sat Dec 26, 2015 6:12 pm Up
Take the switch out and give it a clean?
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
mtempsch
PostPosted: Sun Dec 27, 2015 6:19 am Up
Disconnect the switch. In the plug on the loom find the +12V and ground going into the switch as well as the two wires going out to the window, and then jumper the incoming to the outgoing. Depending on which way around the +12 and ground are connected that should move the window up or down... The circuit diagrams in the Maintenance Howto forum should be helpful to find the right pins.
That should get the window up for the short term.
Then disassemble and clean the switch. Water, isopropyl alcohol/water mix. Last rinse I'd use pure alcohol for faster avaporation/drying. Or source a new switch.
Silvermetallic 2004 206 RC
Lovepeugeot
PostPosted: Mon Dec 28, 2015 8:19 am Up
Thank you all going to get onto it now
Sim
PostPosted: Mon Dec 28, 2015 8:44 am Up
Could you not short circuit the switch terminals itself?
EV (roadtripper)
GTC VXR (sold)
mtempsch
PostPosted: Mon Dec 28, 2015 10:01 am Up
That's effectively what I describe, but with the lump of the switch out of the way. If you've got enough slack in the loom to easily get at the back of the connector while attached to the switch, it can be done on the backside of the connector as well.
It's also two sets of terminals, incoming ground to outgoing1 and incoming +12 to outgoig2, since the wires to the window motor shift polarity depend which way the window is to move, none of them have either constan +12 or constant ground.
You can do effectively the same by running loose wires from a battery and poke the motor terminals directly, out in the door.
Edited: s/look/loom/
Sim
PostPosted: Mon Dec 28, 2015 3:46 pm Up
Sorry mate, I'm still digesting Christmas foodies:))
EV (roadtripper)
GTC VXR (sold)
Lovepeugeot
PostPosted: Tue Jan 12, 2016 10:54 am Up
Thank you window is now fixed
Page 2 of 2
