Latest: Kifi69
Overall: 17183
Online Now [346]:
Visitors: 345
Today: 112314
Total: 143660964
Forums › The Car › 206 Problems › no manual and need to find the passenger fusebox 1.4 entice?
jimjammy
PostPosted: Thu Jan 07, 2016 9:53 am Up
Hi bought my pug a year ago with no manual. Now im stumped as to where the passenger fusebox is?? as my radio is deceased and also multi funtion display lights are dim. thnks in advance
PostPosted: Thu Jan 07, 2016 12:22 pm Up
Remove the panel below the steering wheel and you'll find the fusebox and BSI unit. A 2p coin turns the screw pretty easily.
jimjammy
PostPosted: Thu Jan 07, 2016 1:45 pm Up
thanks macca but the schematic on this site says the fuse is located in the passenger fuse compartment not the driver one.
PostPosted: Thu Jan 07, 2016 2:30 pm Up
It's the same thing. Passenger compartment fusebox as oppose to the engine bay fusebox.
jimjammy
PostPosted: Thu Jan 07, 2016 4:08 pm Up
ok thats sucks as the schematyic shows radio/ multi function at F18 and mine doesnt have an F18. stumped
PostPosted: Thu Jan 07, 2016 4:19 pm Up
Your car is a multi-plex so will be fuse 15
www.206info.co.uk/Foru...39224.html
jimjammy
PostPosted: Fri Jan 08, 2016 6:16 am Up
cheers macca. thanks for help
AJAC
PostPosted: Tue Feb 16, 2016 8:37 pm Up
Hello. Low MDU display will be bulbs, There are 3 Capless 1.2 Watt bulbs. Check on You tube how to remove MDU on a 206, Very easy. Go to Halfords you might a well change all 3, 2 of mine were blown, Could not see left hand side or middle section
