Latest: S2cgm
Overall: 17178
Online Now [134]:
Visitors: 132
Bots: 2
Today: 41595
Total: 136740809
Forums › The Car › 206 Problems › No Horn & Airbag Fault (is this the cause)?
Go to page Previous  1, 2
Sim
PostPosted: Wed Feb 10, 2016 10:28 am Up
Is this fault the same as with your original Com2000 ?
When fitting airbag back, have you ensured you pushed both airbag connectors all the way in, and then pushed the yellow "ear-clips" on each connector in (they are in essence opening the short circuit pins to prevent airbag from going off)?
(In your original photo blue one has it undone, and green has one in)
A bit hit-and-miss with those Com2000 units.. If I lived anywhere nearer, I could offer trying it on my car (just had a Com2000 replaced, but will need to remove again since ribbon cable reel has been wound up too tight and I hear squeel on full right-lock Smile )
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
tommyb32
PostPosted: Wed Feb 10, 2016 1:43 pm Up
i just stuck a resistor in the wiring to the com2000 and the fault has vanished yey lol Laughing
Sim
PostPosted: Tue Feb 16, 2016 10:11 am Up
Lol! Well done with the hack!
If you plugged an airbag (blue or yellow) connector to a resistor, instead of actual airbag, means airbag assembly itself is faulty. Am I right?
Hope you'll sort the airbag itself soon too, better safe than sorry
EV (roadtripper)
GTC VXR (sold)
Page 2 of 2
