Latest: cogeim7
Overall: 17185
Online Now [911]:
Visitors: 910
Today: 163070
Total: 147276959
Forums › The Car › 206 Problems › gti 180 Rear Axle Stabilisers
Peynut
PostPosted: Sat Feb 06, 2016 10:45 am Up
im after the rear anti roll bars for my gti 180 they have quoted me 82 each at peugeot dealers and i have found some online for an SW estate and i was wondering if they are the same ?
www.ebay.co.uk/itm/141...EBIDX%3AIT
PostPosted: Sat Feb 06, 2016 5:15 pm Up
They aren't anti roll bars. But they are the same as SW models.
Peynut
PostPosted: Sun Feb 07, 2016 4:53 pm Up
i wasnt sure what they was called to be honest mate. oh that's good
i didn't want to buy them and find out they don't fit .. i will have to buy some mot is due shortly lol
PostPosted: Mon Feb 08, 2016 1:51 am Up
You could get it through an MOT with the bars removed!
Peynut
PostPosted: Thu Feb 11, 2016 5:36 am Up
ahh brilliant thanks for that .so is the back axle the same as any other normal one like off my 1.6 16 valve one ?? as i have had a refurbed axle on that a couple of month back from imaxle then clutch died .. cars just sat there
mtempsch
PostPosted: Thu Feb 11, 2016 12:00 pm Up
On my last [Swedish equivalent to] MOT the tech asked me if I had added the stabilizer bars as aftermarket upgrades myself...
Informed him they were stock on RCs (180s) and SWs.
Silvermetallic 2004 206 RC
mtempsch
PostPosted: Thu Feb 11, 2016 12:10 pm Up
Not 100% sure, but I think it's been said here that not all axles has the attachment points for the bars.
think you also need the right version of brakes/sensors for the ABS/ESP too, but if the axle has the attachment points and S16 is multiplexed you should, AFAIK, be OK. If not multiplexed I think you'd need to transplant your hubs to the S16 axle.
Someone please correct me if I've got this wrong.
southwestchap
PostPosted: Fri Feb 12, 2016 5:44 am Up
Axles tubes are the same across the range. Apparently on some GTi ones, they have one pin at 47mm and the other at 50mm(?) I've just stripped a 180 one and that had both 47mm pins, same as a 1.9D one I have and also stripped.
Two types of brake drums, larger ones (mainly found on ABS models - but also seen on non ABS 206s) and the smaller earlier drums that early 306s used to run.
Then you get disc ones that are the same across the range (247mm discs IIRC)
Torsion Bars - Generally 19mm in the lower specs think my SW had 19mm too.
ARBs - Again 19mm I've seen on LX models, 180 one is 22mm, SW was 20mm.
Dont take this as gospel, only what I've come across.
