Online Now [496]:
Visitors: 495
Today: 100899
Total: 105429299
Forums › The Car › 206 Problems › MOT Fail Rear Axle
MOT Fail Rear Axle
niki945
PostPosted: Sat Feb 13, 2016 5:46 am Up
OK my car has just failed its MOT on rear suspension - apparently I need a new rear axle and I've been quoted MOT for 2nd hand part and fitting - does this sound about right?
niki945
PostPosted: Sat Feb 13, 2016 5:59 am Up
offside rear Torque/reaction arm has excessive play in a pin/bush (2.4.G.2)
Nicola xxxxxx
macj
PostPosted: Sat Feb 13, 2016 6:14 am Up
sounds fine.... there are alternatives with repair kits available
niki945
PostPosted: Sat Feb 13, 2016 6:34 am Up
is it not the whole rear axle which need replacing then? Just an arm? Literally stuck for what to do! I haven't a clue about these things!
Nicola xxxxxx
MrWhite
PostPosted: Sat Feb 13, 2016 7:54 am Up
could get a refurb fited with brand new bearings and stub pins etc. around £200 if i remember www.axledirect.com
My 206 Project Thread
PostPosted: Sat Feb 13, 2016 8:19 am Up
I imagine plenty of used axles are past their best now. Safest bet is a refurbished axle.
niki945
PostPosted: Sat Feb 13, 2016 10:59 am Up
Thanks guys
Nicola xxxxxx
Peynut
PostPosted: Sat Feb 13, 2016 2:43 pm Up
i just replaced the whole lot was best option, imaxle did mine
