Latest: Beduff1977
Overall: 17134
Online Now [472]:
Visitors: 471
Today: 116458
Total: 107297204
Forums › The Car › 206 Problems › Start up issues
Start up issues
Puglife206
PostPosted: Tue Feb 16, 2016 1:00 pm Up
Hi all , thanks in advance for any help.
I recently purchased an 02 reg 206 1.4 with 35,000 miles on the clock.its been a good car so far .The last 2 weeks I've had a problem once starting up the car.
It actually starts ok but ideals rough on first start up of the day, touch the accelerator and it cuts out unless you quickly Rev it aggressively.
Any ideas ??
Puglife206
PostPosted: Tue Feb 16, 2016 2:09 pm Up
Just looked through your solved problems sub page sounds like someone had same problem ,and so a clean of my throttle bodie and ICV, I've read through a great how to piece on cleaning the throttle body, the stepper motor is that what's otherwise known as the ICV ??
PostPosted: Wed Feb 17, 2016 1:15 pm Up
Stepper motor / ICV are the same thing.
cainw1
PostPosted: Wed Feb 17, 2016 2:04 pm Up
It could be the temperature sensor, I've seen a similar problem on a 1.6 8v and also on my '180. Changing the coolant temperature sensor fixed them both and they aren't expensive or hard to fit
