Latest: jackrox1992
Overall: 17186
Online Now [936]:
Visitors: 935
Today: 140873
Total: 148088062
Forums › The Car › 206 Problems › Car wont start - electrical fault
lucasmeister
PostPosted: Mon Feb 22, 2016 1:30 pm Up
Hi guys,
I'm hoping somebody can shed some light on my problem as I'm currently at a loss.
I have a 206 1.4 2006 reg that was parked for a couple of days and then refused to start. It turned over just fine but didn't start.
Had it towed to a reputable garage that I usually use. After checking it over they were certain it's an electrical fault, more specifically with BSI.
They tried rebooting it & checking the wires out of the BSI ec but didn't find anything. I also checked the keys myself by leaving in the ignition and opening the door to check for a beep.
So they sent the BSI and ECU off to a "specialist" that they use, to take a look. Nothing was found apart from a wiper error in the BSI.
This is where I'm at now, and I'm not sure what to do next, as I've already spent a tonne on labour costs. It sounds very much like trial and error now, going through checking all the different wires etc.
I'm grateful for any advice...
Cheers
PostPosted: Mon Feb 22, 2016 5:48 pm Up
Have they checked the earth point on the gearbox?
Very common for the wires to break off the terminal on them at this age and cause a lot of issues including not starting but turning over. Very easily overlooked as well.
PostPosted: Tue Feb 23, 2016 1:32 am Up
Has the car been tested with Peugeot Planet?
PostPosted: Tue Feb 23, 2016 6:10 am Up
It's better to be tested with Peugeot Planet to know what the problem,as guessing is not going to work in this case,but you might have a crank sensor faulty,which can cause the same problem your can have.
PS1000
PostPosted: Wed Feb 24, 2016 11:10 am Up
I had a similar problem and was told it was a BSI fault (which I did not agree with - so I did not send it away). It turned out to be the crank sensor - £30 to fix. Recommend making sure the garage you are using has PP2000 and that they do check the crank sensor
lucasmeister
PostPosted: Thu Feb 25, 2016 11:24 am Up
Thanks for the ideas.
I've asked them if it could be the crank sensor and they say it would have shown up with their diagnostic software if it was. Is that right?
Not sure if they have Planet Peugeot. Will ask the question. Will also ask about the gearbox earth.
lucasmeister
PostPosted: Mon Feb 29, 2016 7:16 am Up
Turned out it was a broken wire behind the dashboard, so all good now!
However, the central locking no longer works. They say I need to resync it? Any idea how this is done with my car model?
Cheers
lucasmeister
PostPosted: Mon Feb 29, 2016 11:55 am Up
I followed some instructions online, however it didn't work.
I seem to have an aftermarket key fob, which I've always used. Not sure if that makes a difference when trying to re-sync?
