Online Now [173]:
Visitors: 173
Today: 84007
Total: 142466761
Forums › The Car › 206 Problems › knocking noise when starting car
tommyb32
PostPosted: Wed Feb 24, 2016 1:27 pm Up
so im getting a knocking noise when starting the car. once its ticking over it stops, seems to be when the engine is shuddering to life just before it starts to idle. Took it for its MOT today dropped car off and no noise at all, go to pick it up and it's knocking. could it be something the garage has done or something like an engine mount that just had bad timing?
PostPosted: Wed Feb 24, 2016 3:20 pm Up
Was it knocking before you took it in? If not i'd take it back and ask them to take a look.
PostPosted: Thu Feb 25, 2016 4:37 am Up
Usually a knocking sound when starting the engine means you have one or more engine mounts needs to replace it,the engine have 3 mounts by the way,left one,and right one,and a lower one.
gazza82
PostPosted: Thu Feb 25, 2016 7:30 am Up
Could also be the main crank pulley. Some are rubber mounted and the rubber deteriorates ..
