Latest: cogeim7
Overall: 17185
Online Now [706]:
Visitors: 705
Today: 181245
Total: 147079598
Forums › The Car › 206 Problems › Headlight remains on and turn signal won't work
relliyan
PostPosted: Mon Mar 14, 2016 11:31 pm Up
Hi, i had a problem with my 2002 206 this morning, while i was driving the dashboard lights would suddenly come on and my headlights and my wipers started.
The most annoying thing is that my turn signals didn't work and when I turn off the car, the headlights remained on, I had to disconnect the battery wait several minutes then put it back on...
Last year I had the same problem for a week or two on and off, then it seemed to go away by itself...
Could someone help me to get an idea on whats happening?
PostPosted: Tue Mar 15, 2016 4:07 am Up
Normal symptoms of a com2000 failing. They can be repaired but easier to buy a new one.
relliyan
PostPosted: Tue Mar 15, 2016 5:02 am Up
I'll check on that and give an update asap.
PostPosted: Wed Mar 16, 2016 6:58 am Up
I second that Smile
PostPosted: Wed Mar 16, 2016 7:39 am Up
BSI unit has gone in to downgrade protection mode.
Stick it on Peugeot Planet & see what faults are flagged / stored.
I would suspect a global scan will show Com2000 = presences of faults.
