Latest: tbafonso
Overall: 17130
Online Now [262]:
Visitors: 261
Today: 35774
Total: 103621584
Forums › The Car › 206 Problems › How to bypass the heater matrix?
jackpf
PostPosted: Thu Mar 24, 2016 5:25 am Up
Hi,
I have leaking coolant in the passenger footwell, and from reading up it seems like this is the heater matrix leaking.
It seems like replacing the entire heater is a difficult job, and I'm not too bothered about being warm, so is there any way to simply bypass the heater matrix? Google isn't being too helpful.
Cheers,
Jack
David1156
PostPosted: Thu Mar 24, 2016 7:04 am Up
You may be able to block the pipes before the bulkhead but don't quote me on it. It's not really that difficult to do as you don't have to take out the dash despite what everyone says. I personally ran half a bottle of radweld through the system
Current: Albi Blue Clio 197
jackpf
PostPosted: Thu Mar 24, 2016 7:36 am Up
Ah cheers, I'll give it a go.
I have seen videos of doing it without taking out the dash but it still looks a bit complicated and I need a bit of a short term fix for now.
Cheers.
PostPosted: Fri Mar 25, 2016 4:39 am Up
It doesn't just keep you warm though. It helps stop windows from steaming up.
jackpf
PostPosted: Fri Mar 25, 2016 6:34 am Up
Can be done by opening a window though Smile not gonna be pleasant in winter but I'd rather have a working engine than be nice and toasty!
PostPosted: Fri Mar 25, 2016 10:22 am Up
Opening a window won't dry the windscreen.
FrankAteMyName
PostPosted: Sun Mar 27, 2016 2:17 am Up
I had to drive with the matrix bypassed for quite a while but it is doable - even if dangerous. Just make sure if this get steamy you pull over and make sure you can see.
Generally, blocking coolant pipes is considered bad practice so I'd avoid that for obvious reasons.
However, making a u bend out of PVC pipe offcuts works as I have done it. You'll need 3 little offcuts and 2 elbow joints. A couple of O rings should keep it all together. Try and get the pipe just a little thicker than the two rubber pipes on the engine side of the bulkhead (the ones that go to the matrix). Unplug those, stick the u bend in and bleed the system and hey presto leak averted.
I'll upload a picture later or Tuesday.
Remember: 9 times out of 10 the matrix itself if sound but coolant is actually leaking from the 2 plates where the plastic pipes join the matrix. If this is the case it can be fixed with any generic O ring set or you can get them from Peugeot for £15.
I have the part number somewhere but if you ask for the heater matrix piping and O rings they'll know what you mean. Make sure to check for leaks before buying a new matrix.
Hope that helps.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
PostPosted: Mon Mar 28, 2016 2:40 am Up
Just get things done right,and fix the heater matrix leak,as this is the right thing to do for your safety,my car is LHD,and got the heater matrix out and fixed the leak I had from the o-rings,other have a bad matrix,which you can replace easily Smile
