Online Now [110]:
Visitors: 109
Today: 56080
Total: 138912531
Forums › The Car › 206 Problems › No servos work digital climate
mcfly666
PostPosted: Wed Mar 30, 2016 2:56 pm Up
looked at a friends aircon problems again after bleeding the brakes.
There is no movement from any of the servos controlling if air comes from outside, recirculated hot/cold nothing.
Any ideas?
1.9d tank
FrankAteMyName
PostPosted: Thu Mar 31, 2016 2:05 am Up
Might help if you post details of the car:
Year, Mileage, MUX or pre, did they work before
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
FrankAteMyName
PostPosted: Thu Mar 31, 2016 5:42 am Up
And I'd recommend poking around with a multimeter to see if they're getting power. If they are then check if they're getting signal. My guess is that one or the other is missing because they wouldn't all just... die.
Have you had any work done on the car recently?
My cars:
mcfly666
PostPosted: Thu Mar 31, 2016 12:15 pm Up
Hi, it's for a friend so I don't have full details.
It's a 1.4 GLX 03 plate, Don't know about power. But none of them are moving, my thoughts that they wouldnt all go at one so I'm wondering if it's the digital controller that's failed.
1.9d tank
FrankAteMyName
PostPosted: Thu Mar 31, 2016 12:36 pm Up
You can pick up a control panel for 15 quid delivered but I'd recommend testing first with a multimeter
My cars:
mcfly666
PostPosted: Thu Mar 31, 2016 1:21 pm Up
Are the servos fed live from elsewhere, or does live run through the control unit. If the live runs through the panel I don't know what else it could be.
It's a friend of mine, who lives a fair way away so instead of going too and fro it saves time and money to have most things it could be with me if that makes sense.
1.9d tank
FrankAteMyName
PostPosted: Fri Apr 01, 2016 12:03 am Up
Does your friend happen to own a multimeter that they can have a poke around with? That's going to be the quickest way to get any sort of idea as to what's going on. Also, how do you know the servos aren't turning? Because there's no change in temp?
My cars:
mcfly666
PostPosted: Tue Apr 05, 2016 6:42 am Up
Hi, you can see one servo and its gear mechanism when you look up behind the dash from the fuse's, I've put a screwdriver on the others and listened for movement and there is nothing.
Absolutely nothing from the servos work, no change in temp, no AC, no moving the air to come from the footwell or to the wind shield. All servos are dead.
Like you say they wouldn't all go at the same time I think, so its a power issue. No offence to the fairer sex, but I don't think she can fault find with a multi meter.
I think these servos are a resistance type with no active switches inside them so I guessing all power for them goes through the front control panel.
1.9d tank
FrankAteMyName
PostPosted: Tue Apr 05, 2016 7:59 am Up
I dug out one of my old looms from the parts bin and I agree, the servos are driven by the control unit (powered and controlled).
Have you by any chance removed the control panel from the fascia assembly to take a look? IIRC the servos are driven by a different connector to the rest of the system so that would be where I would take a look for any obvious signs of damage (corrosion, snapped cables, anything out of the norm really).
My cars:
mcfly666
PostPosted: Fri Apr 08, 2016 5:50 pm Up
the idea of different connector powering the servos is is a great help. now im wondering if they run in series where if one looses power they all do.
the dash has been out and it would not surprise me if someone has caught or broken the loom.
Ive had the control unit out, but there was no obvious damage
1.9d tank
FrankAteMyName
PostPosted: Sat Apr 09, 2016 10:36 am Up
I imagine they are wired in series. There's a white connector plugged into the side of the control panel. If you can access one of the servos then you could check continuity between those points
My cars:
mcfly666
PostPosted: Tue Apr 26, 2016 3:22 pm Up
Thanks for your input FrankAteMyName, unfortunately I have not looked at this car again due to other mechanical problems that I've been sorting out.
I think I can access a servo under the drivers seat easy enough though, I will get back to you.
1.9d tank
